Tire size #706891 03/16/06 05:18 AM
i am getting new tires for my 91 trooper with the v6. i am considering 31 x 10.5's but would like a wider 32 or 31 x 11.5's. i just need to know if i will burn through a tranny, or my motor too quickly with the 11.5's.
Re: Tire size #706892 03/16/06 05:30 AM
9
94redrodeo Offline
32X11.50's are fine and you don't need alift for them 33's and up is where your power goes bye bye
94 Rodeo 3+3 lift Red)
95.5 Rodeo 1" Body lift Dana 44' front & rear 4.88 gears 35"s 176,000 miles Optima Yellow top InexAir Co2
front winch bumper custom rear bumper, Hella 500's
2004 Silverado duramax
Re: Tire size [Re: 94redrodeo] #706893 03/16/06 12:18 PM
TrooperChris Offline
I would agree witht hat mostly, BUT I have just put 33x10.50s on my 88 Troop with the 2.6 and my power did NOT go down at all. The thing to look for is the width of the tire...that seems to really zap the power
My .02,
Chris
1988 Trooper: 2.6L Delta Cam, Pacesetter Header, K&N, 2 1/4 exhaust, CB, Lights by Hella, Warn Hubs, 6.5 inches of lift thanks to DOR and PA, Rancho 9000x's, 33X12.50 Durango MTs
1995 Nissan Maxima...the DD :-)
Re: Tire size [Re: TrooperChris] #706894 03/16/06 03:27 PM
strawmyers Offline
Isuzu Moderator
I can't speak for your experience... but from a physics (or some kind of math <img src="/forums/images/graemlins/notooth.gif" alt="" /> ) standpoint, height should be the bigger factor. Putting on taller tires has the same effect as putting in shallower differential gears... it lowers the RPMs and, as a result, your vehicle is putting out less power at the same speed. Width, tread type, etc will also have an effect in the form of rolling resistance. I know just going from the stock 31x10.50 to a 32x11.50 came with a noticable decrease in power and braking ability.
Sean Strawmyer
Re: Tire size [Re: strawmyers] #706895 03/17/06 06:00 AM
maxwell417 Offline
I have 33x10.50 BFG Mts on my 89RS Trooper. There was minimal loss of acceleration from 31s. I think overall weight of the wheel tire combo can make a bigger difference than height.
Curt B 89RS Calmini Header Delta Cam 33x10.5 BFG MTs & 90 Trooper 3.4 v6, SAS D44 ARB/Hobart 5.38s 35s my pictures
Re: Tire size [Re: maxwell417] #706896 03/17/06 06:08 AM
holger Offline
I hope you guys do not fool yourself. When I made a very modest tire size change, from stock 30" to 31", my relatively modern and powerful Rodeo did feel the difference. When I hear people switching to 33 with "minimal loss of acceleration", on older trucks, I wonder how it's possible.
Oleg
Deceased Rodeo'02 4WD.
Re: Tire size [Re: holger] #706897 03/18/06 01:46 AM
MountaineerIsuzu1 Offline
AGREED!
Re: Tire size [Re: MountaineerIsuzu1] #706898 03/18/06 02:38 AM
maxwell417 Offline
It is all about the gears .... 89RS has 4.77. Trust me it run fine, cruiing 75 mph is no problem.
Re: Tire size #706899 03/18/06 02:50 AM
Y
ybnormal70 Offline
One thing I think really changes the power is the weight of the tire also. Here is what I found when looking for tires for my Trooper. This is for BFG MT's:
31x10.50 weighs 43lbs
33x10.50 weighs 48lbs
33x12.50 weighs 64lbs
Going from a 31 to 33x10.50 is only 5lbs per tire, but to a 33x12.50 is 21lbs per tire. So for 4 33x10.5 it is only 20lbs extra of tire and for a 33x12.5 would be 84lbs extra of tire. That is alot of rotating mass, almost like having a 6wheel 31x10.50 Trooper smile.
Also, think about this. If you have almost bald 31x10.5's and go with 33x12.5's, I bet that would be over 100lbs different. That would seem to make a big difference.
L8r,
Kevin
'94 Trooper S 3.2SOHC, 5spd, Aisin hubs, OME919 w/ 2" coil spacers, Edelbrock shocks, fliped BJ's and spacers, 15" snowflakes w/33x12.50x15
PHP: 7.4.33 Page Time: 0.011s Queries: 15 (0.007s) Memory: 0.6255 MB (Peak: 0.7288 MB) Data Comp: Off Server Time: 2026-11-01 16:58:25 UTC
