i think my rearend is going out #707107 03/17/06 07:11 AM
blue97sr5 Offline OP
yeah while driving i let up off the peddle and i hear a noise from the rear. it sounds like a thumping, like a gas quad at idle.
check the fluid in the dif. and its dark grey(i changed it about 6 months ago) then i checked the t-case and it looks way better.
how much can i get a rebuilt 3rd member for???
97 sr5 tacoma: TRD air filter, bilstien shocks, and a crazy sound system
mods soon to come
B&M short throw
TRD headers
MagnaFlow catback
Re: i think my rearend is going out [Re: blue97sr5] #707108 03/17/06 03:03 PM
little_joe Offline
Former Admin
Have you eliminated your u-joints/double-cardan or slip yoke as the source of the problem?
When the u-joint was gone on the pinion end of the driveshaft of my old truck, it felt nice and tight while mounted on the truck but made some awful noises (which I thought was the ring and pinion). I pulled the driveshaft off and noticed the u-joint had fallen apart - caps were cracked, needle bearings were gone.
Give everything a good inspection, then a greasing, and pull the DS if you have to.
It's natural for the gear oil to turn dark, remember your rear 3rd is always working but your t-case isn't.
4x4Wire's Toyota Section
1995 FZJ80 LandCruiser - 3 locking diffs, +200k mi, JD HIR's, 285/75R16 Nitto TG's
Olde North State Cruisers
Re: i think my rearend is going out [Re: little_joe] #707109 03/17/06 09:51 PM
4WD22R Offline
X2 for the drive shaft or u-joints, my drive shaft ran out of lube in the slip joint and it started making a horrible racket while driving.....lubed it back up and all is happy now <img src="/forums/images/graemlins/kewl.gif" alt="" />
-1986 TOYOTA
22R
ZUK coil rear
Torqued T-Bars
Marlin HD clutch
AZTTORA #492
TLCA member
"I hear there's rumors on the Internets that we're going to have a draft."
--George W. Bush
PHP: 7.4.33 Page Time: 0.009s Queries: 15 (0.006s) Memory: 0.5943 MB (Peak: 0.6479 MB) Data Comp: Off Server Time: 2026-11-02 12:33:25 UTC
