Vacuum at idle
#707318
03/17/06 09:31 PM
Just a quick question for you guys and gals:
What kind of vacuum should a '86 22R pull at idle? Mine's pullin about 21 In/Hg and I can drop it to 0 In/Hg by putting the throttle all the way down...
Sound about right?
Thanks!
-1986 TOYOTA 22R ZUK coil rear Torqued T-Bars Marlin HD clutch
AZTTORA #492 TLCA member
"I hear there's rumors on the Internets that we're going to have a draft." --George W. Bush
Re: Vacuum at idle
[Re: 4WD22R]
#707319
03/18/06 01:57 AM
that is perfect. a good running engine should have 17- 21 at idle, OH and it should be steady and not bouncing.
Re: Vacuum at idle
[Re: 1986xtracab]
#707320
03/18/06 03:50 AM
what is bouncing? mine moves about 1 in/Hg that good?
Re: Vacuum at idle
[Re: 4WD22R]
#707321
03/18/06 04:25 AM
Re: Vacuum at idle
[Re: 4Crawler]
#707322
03/18/06 09:13 PM
<img src="/forums/images/graemlins/kewl.gif" alt="" /> Thanks Roger! Guess it's time to go check the gap in the ole spark plugs <img src="/forums/images/graemlins/smile.gif" alt="" />
Re: Vacuum at idle
[Re: 4WD22R]
#707323
03/19/06 12:06 AM
ok whill the topic is up rather than starting a new one.... i pull a steady 19 at idle and at 3000 rpms the needle fluctuates between 20-24. what could cause this..is this normal. as you all no im still trying to figure out my rough idle situation...any ideas
91 pickup 5.29's US GEAR.35x 12.50 trxus m/t.5 speed swap- SOLD! 96 4Runna limited-toytec/OME lift,diff drop Nitto 285/75/16 Elocked=butter 07 FJ cruiser 3" DR coilovers 285/75/16 nitto TG. allpro sliders
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6094 MB (Peak: 0.6790 MB) Data Comp: Off Server Time: 2026-07-09 16:05:59 UTCValid HTML 5 and Valid CSS
