91 'Yota 4x4 Brake Rotor Replacement Help #707569 03/18/06 10:56 PM
Lookin for help here.
I have a '91 Toyota 4x4 PU. I had one of the right front brake caliper pistons sieze up, and I now need to replace the caliper and rotor. I have the front end disassembled to this point:
Wheel and caliper is removed.
Front locking hub is removed (cone washers were a booger!).
I'm at the point of removing the hub from the axle, and I want to grease the wheel bearings while I'm in there. I'm now looking at what appears to be about a 54mm nut, with some sort of clip or locking mechanism behind it that is keeping it from rotating. How do I get this nut removed?
Another question. This truck has almost 200,000 miles on it. I notice that the front axle stub (the splined part that extends through the hub and engages the Aisin locker, has about a 1/16" degree of up and down and side to side play in it with the locker removed. Is this normal? Is there a bushing or bearing that needs to be replaced? I didn't notice any play when the Aisin locker was still bolted on.
Re: 91 'Yota 4x4 Brake Rotor Replacement Help #707570 03/19/06 02:21 AM
little_joe Offline
Former Admin
4x4Wire's Toyota Section
1995 FZJ80 LandCruiser - 3 locking diffs, +200k mi, JD HIR's, 285/75R16 Nitto TG's
Olde North State Cruisers
Re: 91 'Yota 4x4 Brake Rotor Replacement Help #707571 03/19/06 09:41 AM
4WD22R Offline
Marlin sells the socket you're lookin for......or you could just use a hammer and a chisel to get it off.....
-1986 TOYOTA
22R
ZUK coil rear
Torqued T-Bars
Marlin HD clutch
AZTTORA #492
TLCA member
"I hear there's rumors on the Internets that we're going to have a draft."
--George W. Bush
Re: 91 'Yota 4x4 Brake Rotor Replacement Help #707572 03/19/06 10:01 AM
kewlynx Offline
54mm or 2-1/8" socket, with a 1/2" to 3/4" drive adapter. Joe gave you the link. The CV axle end just kind of floats thru the hub; it's fine.
If the rotor is coming off, then you'll want to pack the spindle assembly bearings while it's apart.
Have fun; do ONE SIDE at a time.
**ubi apis- ibi salus**
Re: 91 'Yota 4x4 Brake Rotor Replacement Help [Re: 4WD22R] #707573 03/19/06 03:47 PM
V
vtown Offline
Yeah, I used the hammer/punch technique myself. Worked fine since the nuts aren't all that tight. Saved me the trip to sears and the $20 that socket prolly costs.....
On that locking washer, just need to bend the tabs straight and viola, you can loosen the nuts.
Enjoy
Re: 91 'Yota 4x4 Brake Rotor Replacement Help [Re: vtown] #707574 03/19/06 05:10 PM
OK, thanks guys. I actually found the web site referenced above, and pretty much have it all apart now.
I'm trying to get the rotor off of the hub, now. With the locked-up caliper piston, it got pretty hot. It's also pretty rusty. I'v it all on my bench now, and am soaking the hub/rotor assembly in penetrating oil now, hoping to break 'er loose.
New parts are on order.
Hope to have her back together next weekend.
BTW, I was able to get the wheel bearing nuts loose with just a channel-lock.
I think I'm going to buy the proper-size socket today. I find that, once you buy that special tool you need, you will never have to perform that job again.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6131 MB (Peak: 0.6833 MB) Data Comp: Off Server Time: 2026-05-30 01:19:08 UTC
