Shot rods out block #707871 03/20/06 12:51 AM
N
nateyesme Offline OP
Well a couple weeks ago I was taking my 93 v6 pu through some puddles and I guess I went into one a little to far and it died in the middle..lol. My friend pulled me out I looked at the bottom of the block and I shot 2 rods staight out of the block. Water got into the engine through the air intake so im guessing thats what did it..kinda stupid on my part. But anyway i'm wondering if there are any good places to get an engine or any simple engine swaps that would not cost over 5k?
Re: Shot rods out block [Re: nateyesme] #707872 03/20/06 02:48 AM
V
Voyager Offline
You should be able to get a remanufactured long block for far less than that. Pay someone to put in in & you may be up there.
Here are the links to my engine search in order from cheapest to most expensive.
1 2 3 4
For much cheaper you can also locate low mileage used, but for the effort of replacement I would go with a reman longblock. My .02
Sid
89 extra cab 4x4 3.0 5 spd, 216K
4.56, Supra LSD, Lock Rite
Re: Shot rods out block [Re: Voyager] #707873 03/20/06 05:11 AM
Jake97T Offline
if 5k is your limit you may just want to spend a few thou on a 3.4 and swap it...engine swap kits are available offroad solutions in colorado
Re: Shot rods out block [Re: nateyesme] #707874 03/20/06 07:54 AM
RAZZMATAZ Offline
Assuming your current truck is not all tricked out it would seam more feasible to purchase another used truck !?!?!?
Just a suggestion.
87 4Runner 22R-TE
4 Pro Comp IFS
63 Chevy springs
5.71 gears
Detroit in rear, Lockright in front
35 MT/R
Rancho 9000
Jacobs ProStreet ign module and Ultra coil
1992 3VZ-E swapped in
Re: Shot rods out block [Re: nateyesme] #707875 03/20/06 02:36 PM
ToYPU Offline
5k is the limit?!?
if you have a garage start looking for a 3.4L V6 from a WRECKED toyota or 4 runner
http://www.4x4wire.com/toyota/projects/basham_4runner/
kevin
22RE OWNERS CHECK FOR DEBRIS IN YOUR OIL PANS! YOU MIGHT SAVE YOUR MOTOR!
*** 1989 Toyota pickup 22re 5spd 4wd ***
* New mods *
  • 305/70/R16 (33X12.5)
  • 2 in suspention lift (zuk coils)
  • minor body work
PHP: 7.4.33 Page Time: 0.009s Queries: 15 (0.007s) Memory: 0.6069 MB (Peak: 0.6714 MB) Data Comp: Off Server Time: 2026-11-02 21:50:46 UTC
