cheap winch mount? 89 pickup #708068 03/20/06 03:39 PM
ToYPU Offline OP
hey guys,
looking for a cheap way to mount my 9k winch to my 89 toyota pickup. would like to mount it up front and obvoiusly make it real stout... any ideas? cheap is key! can do some welding if i have to...
thanks
kevin
22RE OWNERS CHECK FOR DEBRIS IN YOUR OIL PANS! YOU MIGHT SAVE YOUR MOTOR!
*** 1989 Toyota pickup 22re 5spd 4wd ***
* New mods *
  • 305/70/R16 (33X12.5)
  • 2 in suspention lift (zuk coils)
  • minor body work
Re: cheap winch mount? 89 pickup [Re: ToYPU] #708069 03/21/06 02:51 AM
trythis Offline
Weld up a framice(frame like device) that holds it where you want it, should be easy and if you use 3/8 inch think steel with gussets, it wont break.
Re: cheap winch mount? 89 pickup [Re: trythis] #708070 03/21/06 03:32 PM
missouriman Offline
look at the front of the frame, there are some stock bolt holes on the bottom.
I ran two heavy pieces of angle iron from those and but a plate on the top..
it sticks out kinda far.
Re: cheap winch mount? 89 pickup [Re: missouriman] #708071 03/21/06 07:55 PM
ToYPU Offline OP
did you oversize the holes and use thicker bolts? how big is your winch?
thanks!
kevin
* New mods *
  • minor body work
Re: cheap winch mount? 89 pickup [Re: ToYPU] #708072 03/23/06 12:06 AM
indy Offline
Here's some ideas:
In my first try I built this bumper for about $160 or so.
first version
I later reworked the mounting to raise it up at an additional cost of $80.
final version
There are a few more pics of each if you follow the links to my photobucket pics.
Re: cheap winch mount? 89 pickup [Re: indy] #708073 03/23/06 01:19 AM
ToYPU Offline OP
nice job! doesnt look to expensive... just gotta talk my friend into doing some welding!
kevin <img src="/forums/images/graemlins/smile.gif" alt="" /> <img src="/forums/images/graemlins/smile.gif" alt="" /> <img src="/forums/images/graemlins/smile.gif" alt="" /> <img src="/forums/images/graemlins/notooth.gif" alt="" /> <img src="/forums/images/graemlins/notooth.gif" alt="" />
* New mods *
  • minor body work
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.6131 MB (Peak: 0.6832 MB) Data Comp: Off Server Time: 2026-06-07 09:08:43 UTC
