4WD noises when 2WD selected on T-case #708217 03/20/06 09:24 PM
sled207 Offline OP
1990 Montero 5 spd auto free hubs. Driving in 4 HI, normal highway sounds. When I shift to 2WD, the 4WD does disengage, but sounds like the T-case is in 4 LO. Gears whining, but no grinding. When I get below 5mph, I hear a clunk and everything sounds normal. Put it back in 4WD and everything sounds and works fine
Re: 4WD noises when 2WD selected on T-case [Re: sled207] #708218 03/20/06 11:40 PM
Do you back up for up to 12ft after shifting out of 4WD?
Re: 4WD noises when 2WD selected on T-case [Re: sled207] #708219 03/20/06 11:44 PM
LRJ4x4 Offline
Were you driving on the highway in 4HI?
Re: 4WD noises when 2WD selected on T-case [Re: off-roader] #708220 03/21/06 12:08 AM
sled207 Offline OP
Backing up does not seem to help with the noise. Even though the 4WD disengages, the front drive is still turning.
Re: 4WD noises when 2WD selected on T-case [Re: LRJ4x4] #708221 03/21/06 12:10 AM
sled207 Offline OP
I have been driving on snow covered roads in 4 HI.
Re: 4WD noises when 2WD selected on T-case [Re: sled207] #708222 03/21/06 01:56 AM
PartyTruck Offline
Check the oil level on the T-case or just drain it and give it a fresh one. Also did you unlock the hubs?? If you didn't the front driveshaft is turning the FWD part of the t-case wich might explane the noise in 2wd if the chains or bearings are gone bad.
An oil change costs just a few $ and might solve the prob.
1987 SWB Pajero 2.5 TDI on 31" rubber waiting for a hip replacement and bigger shoes
Re: 4WD noises when 2WD selected on T-case [Re: PartyTruck] #708223 03/21/06 02:15 AM
sled207 Offline OP
The hubs are the auto free type. I'm wondering if they are not disengaging. I had trouble getting them to engage the other day. If I had manual hubs in the locked pos, T-case in 2WD, would I not get the same noise while driving?
Re: 4WD noises when 2WD selected on T-case [Re: sled207] #708224 03/21/06 03:22 AM
PartyTruck Offline
If the front propshaft turns when you drive in 2WD they are stuck on and turning the FWD part of the T-case. If the poor thing is a bit worn out it might make a whine if it turns the chains without load from the engine.
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6216 MB (Peak: 0.7031 MB) Data Comp: Off Server Time: 2026-06-23 18:46:16 UTC
