'87 yj speedo #708243 03/20/06 11:34 PM
bhartwell59 Offline OP
hi all,
my speedo needle does alot of shaking between 5-40 mph. about 8 yrs ago i replaced the speedo cable with a new one. didn't solve anything then so i'm finally trying to track this problem down.
what's invloved in a speedometer head replacement? is it a diy job? are there "calibration" issues i need to know about?
-b
4.2 '87 yj, 263,000 miles, mopar mpi, 33" mud bfg, skyjacker 4", 3.73 gears, arb lockers-f and r., tom wood's 2.07 shaft conversion, tom wood's hd driveshaft, magnaflow/custom exhaust, 4wd bumper/swing-out tire carrier
Re: '87 yj speedo [Re: bhartwell59] #708244 03/20/06 11:49 PM
BigJim Offline
Changing out THAT speedo is very simple.. the gear in the transfer case is what adjusts the speedo.. They come in colors and number of teeth to change the reading of the speedo. Your gear might be sticking or worn or loose or something.. I would take it out and clean it up and try it again before changing the speedo..
Re: '87 yj speedo [Re: BigJim] #708245 03/21/06 12:05 AM
bj,
the gear was changed about a year ago... but i'll give it a check. i intend to give the cable a good greasin' also before i do anything w/the speedometer.
but back to the original question: what's invloved in a speedometer head replacement? is it a diy job? are there "calibration" issues i need to know about?
-b
Re: '87 yj speedo [Re: bhartwell59] #708246 03/21/06 01:33 AM
BigJim Offline
To use a modern term it is "plug and play"... It comes out of the dash clean and is in a sealed "can".. No adjustments can be made..(without jacking the can open..) Yep I have done that too. The only adjustment is the number of teeth on the gear.. It might be the needle is running on 20 year old grease but usually it is the cable or gear that causes the jumping.
Re: '87 yj speedo [Re: BigJim] #708247 03/23/06 04:05 PM
got to wondering does it matter what type of grease i use on the speedo cable?
graphite based, all-purpose grease or even 3-in-1 oil?
thanks-b
Re: '87 yj speedo [Re: bhartwell59] #708248 03/23/06 04:37 PM
BigJim Offline
I'd clean the inside case REAL good and then use the grease right out of my grease gun.. Cleaning seems to be more important than the type of grease put back in there the 3n1 oil would be out of the question.
Re: '87 yj speedo [Re: BigJim] #708249 03/27/06 06:08 PM
just an update:
cleaned the inside cable casing and then greased the cable up and, sure enough, needle is rock solid.
thanks again -b
PHP: 7.4.33 Page Time: 0.010s Queries: 15 (0.007s) Memory: 0.6127 MB (Peak: 0.6908 MB) Data Comp: Off Server Time: 2026-11-15 19:36:33 UTC
