Cab/Bed Alignment?
#708306
03/21/06 01:48 AM
Anyone else's pickup not line up quite right? I've noticed this on 2-3 other Isuzu pickups in the area. The front of the bed sits about 1/4-1/2" higher than the back of the cab (body lines don't match up). I'm guessing it's a common problem. Seems weird because I would have thought the tool-box would push the front of the bed down <img src="/forums/images/graemlins/confused.gif" alt="" />
What's the fix? Bushings (and will a body lift kit include those bushings)?
'95 4wd Pickup
Re: Cab/Bed Alignment?
[Re: Jhig]
#708307
03/21/06 03:13 AM
I would assume it is from frame flex within reasonable limits from offroad or towing use etc.. My bed was 1/2" pushed back on the frame.
CHRIS 98 Amigo, 92 Pup
[Re: Jhig]
#708308
03/21/06 05:17 AM
Isuzu Moderator
It is the body mounts and no, a body lift does not replace those. It will be higher, but still lower relative to the bed.
Good Luck, Michael
[Re: mlclark]
#708309
03/22/06 12:12 AM
Thanks, that's what I needed to know.
So, what's a good source for those?
'95 4wd Pickup
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.6037 MB (Peak: 0.6593 MB) Data Comp: Off Server Time: 2026-06-07 04:17:10 UTCValid HTML 5 and Valid CSS
