cams #708716 03/22/06 01:15 AM
stickt4 Offline OP
my 22r has about 18,000 miles on it and i would like to put a larger cam in it but i would like something i can just swap in and use stock valves and springs what have ya'll run and what would you recommend.
Re: cams [Re: stickt4] #708717 03/22/06 01:41 AM
ArbitraryNotion Offline
EB sells great stuff. Check out his site www.ENGNBLDR.com I run his stuff with pride. <img src="/forums/images/graemlins/cheers.gif" alt="" />
1986 Toyota 4x4 22wEBer
Ported EB Offroad H/O Head "Josh Cam"
Ported Intake & Weber38mm Carb
LCE Header & 2.25in Exhaust
RB 1" BL, RS5000, SAW Tbars
2011 FJ Cruiser - SOLD
Re: cams [Re: stickt4] #708718 03/22/06 03:30 AM
JaredT Offline
I just ordered EB's brand new rv head and 268 cam for my 85 4runner yesterday. Looks as though he has good parts for fair prices. He has a cam just for the carbureted engine do not be afraid to email him he usually replies within a few minutes. Jared
Re: cams [Re: stickt4] #708719 03/22/06 04:04 AM
TexJeff87 Offline
I have an EB cam...just a matter of swapping it out and adjusting the valves. Know that if you break the head loose to do the swap, you should do the head gasket, too. At least that's my opnion. I seem to recall a healthy discussion about that recently. But as it's a carbed motor, it's no biggie.
Tell you what, I'd go with whatever EB says.
If Mad Max had a 4runner...
Re: cams [Re: TexJeff87] #708720 03/22/06 08:29 AM
david in germany Offline
I went with another brand than EB when I did mine. The power increase is great but adjusting the valves was not a one time thing to get them quiet. I think I have different clearences on most of the valves now just to keep them quiet. I have heard this is not a problem with EB's cams though. Next one I do I will go with EB products.
David
1987 4runner sr5 22re (almost stock) bigger cam, manual hubs, and the paint is real ugly!
Re: cams [Re: david in germany] #708721 03/22/06 08:36 AM
kewlynx Offline
Bear in mind that worn valve adjustment screws can also come into play with valve noise; flat spots on a convex surface is what you see. Cheap enough to replace.
**ubi apis- ibi salus**
Re: cams [Re: kewlynx] #708722 03/22/06 04:37 PM
Aaron84x4 Offline
i'm running an Isky cam and couldn't be happier <img src="/forums/images/graemlins/kewl.gif" alt="" />
84x4 Toyota Ext. Cab Deluxe
Not enough hours in the day to do what i want.....
.....and sleep
Re: cams [Re: stickt4] #708723 03/22/06 05:59 PM
MrWiretender Offline
Even if the decision is a little close I would go with EB's products every time.
1) the man is honest
2) he knows what he is doing (like few others)
3) no one else in the trade posts regularly on forum helping us out.
4) with 30k miles experience... his stuff works, hassle free and he stands behind everything he sells
5) his pricing is fair
What else can you ask for?
'87 22RE
Re: cams [Re: MrWiretender] #708724 03/22/06 09:05 PM
Brown Offline
I agree with MrW. EB knows these little engines inside and out. I enjoy the engnbldr cam I have in my truck.
Jeremy
SOLD:[color:"666666"]1988 Toyota 4x4 | 22RE | W56 | EB 270 cam [/color]
Re: cams [Re: Brown] #708725 03/23/06 01:35 AM
yodta Offline
I have a Comp Cams 252S.
think the profile's near the same as EB's 261 or his RV cam, can't remember which.
anyway, point is, the low to midrange torque increasing cams are the way to go. some guys put those HP increasing cams on, but they don't make power until up over 4500rpm-5000rpm -- how usable is that to most people?
msg - '87 xtracab
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6297 MB (Peak: 0.7364 MB) Data Comp: Off Server Time: 2026-06-23 18:46:19 UTC
