Page 1 of 4 1 2 3 4
The long block is in...question #708780 03/22/06 03:37 AM
n2dp Offline OP
The long block came in today and I am confused on why they look different. I am sure that someone here can tell me. The first picture is my old engine and the second one is the new one. <img src="/forums/images/graemlins/confused.gif" alt="" />
1988 Raider, 2.6L (Weber carb, PaceSetter header, Centerforce D/F clutch, 5-Speed M/T, 33X12.50 Pro Comp M/T, 15X8 US Wheel 97 Series)
3" Body Lift
Re: The long block is in...question [Re: n2dp] #708781 03/22/06 04:29 AM
52degrees Offline
Balance shaft eliminated?
Clay
KG6VNX
Re: The long block is in...question [Re: n2dp] #708782 03/22/06 04:36 AM
LRJ4x4 Offline
Your new motor has a balance shaft elimination kit. It has no balance shaft, did you order it that way? It will still run fine but you might have slightly more vibration.
Re: The long block is in...question [Re: LRJ4x4] #708783 03/22/06 05:11 AM
n2dp Offline OP
Do I need to cover the hole or is it fine open?
3" Body Lift
Re: The long block is in...question [Re: n2dp] #708784 03/22/06 06:11 AM
LRJ4x4 Offline
Open, the oil will drain down.
Re: The long block is in...question [Re: LRJ4x4] #708785 03/22/06 06:17 AM
52degrees Offline
Do you mean the oil will drain down the outside if it's left open?
I've never had one of those motors apart, but it seems to me that the PCV system wouldn't work either.
Clay
KG6VNX
Re: The long block is in...question [Re: 52degrees] #708786 03/22/06 06:32 AM
LRJ4x4 Offline
Once the timing cover is on it will drain back into the pan. On the side of the block there is a cover for the balance shaft, that needs to be installed.
Re: The long block is in...question [Re: LRJ4x4] #708787 03/22/06 07:13 AM
Jimbotsi Offline
If you look into where the balance shaft used to be there looks like and should be a race press fit into the hole to block the oil passage for the balance shaft. If its left out you will not get proper oil pressure.
87 Monty SWB 208k currently immobile: SOME RUST
89 Quest 61k slightly original
DD---> Integra Rust bucket (gone but not forgotten)
02 BMW M5
Re: The long block is in...question [Re: Jimbotsi] #708788 03/22/06 07:19 AM
Kevin C Offline
I can see the sleeve/plug in the hole for the upper ballance shaft.
Personally I never liked eliminting the ballance shafts. Some are OK with it. The upside is it is less parts to fail and it saves the rebuilder money.
The down side is the motor wont be as smooth and you may notice buzzing and vibration.
Kevin
Re: The long block is in...question [Re: Kevin C] #708789 03/22/06 02:56 PM
n2dp Offline OP
There is a sleeve in the hole, but it is not plugged. How much vibration are we talking and how much does this space affect the oil pressure?
3" Body Lift
Page 1 of 4 1 2 3 4
PHP: 7.4.33 Page Time: 0.008s Queries: 16 (0.005s) Memory: 0.6402 MB (Peak: 0.7627 MB) Data Comp: Off Server Time: 2026-06-21 12:18:06 UTC
