2.6 intake manifold, 93+ TB upgrade? #708874 03/22/06 01:21 PM
jdobbsj Offline OP
Sorry to make a new post for this, but the great original (thanks Marucci!) is in the archives and I wasn't sure it would get much play!
here it is for reference
http://www.4x4wire.com/forums/showflat.php?Cat=&Board=UBB90&Number=264742
As my list of upgrades/plans for the homecoming truck-a-thon continues to grow, I thought about working on the intake/exhaust upgrades many have implemented. Getting into the entire intake setup seems a little overkill/daunting, but simply swapping in the round TB Assembly seems more straight forward. A few questions though.
Is swapping in the round TB assembly of the 93+ intake with the older pre-93 intake worth the trouble (i.e. butt dyno results vs. time/money spent)?
What issues does this simpler upgrade hold in common with the entire intake swap (temp sensor relocation, throttle cable mount, etc)?
lastly.. what is a good source for this relatively obscure part? Anyone have a stash of these laying around or know where we could order such a thing with out explaining isuzu engine design with Earl on the other side of the county and only to risk getting the wrong part anyway?
Thanks, as always, for any info you can share!!
JD
88 Pickup,4x4, 2.6 L, AMC head, K&N Air filter, Aisin Hubs, Redline Oils everywhere, 94 Trooper wheels.
Re: 2.6 intake manifold, 93+ TB upgrade? [Re: jdobbsj] #708875 03/23/06 01:00 AM
Rezkid Offline
If you read the article all the way through you'll find that he states that you can not simply swap the TB's, the mounting holes are a little differnt, and there are some other issues too that he went over. As far as the time/cash/energy vs. gain in power, really thats up to you, you could probably find a used intake from a 93 or so 2.6 in a pick and pull yard for anyware from $25-$100 depending on what kind of operation it is your dealing with. And then comes in the wonderful job of yanking the upper manifold off, which really isn't that hard. All in all, I really couldn't tell you if it's worth all the time, I'm sure you'd "feel" some gain, but who knows. I'm doing the same upgrade on my parent's '88 Trooper, but it's also in conjuction with having the bottom end rebuilt, a new head put on, and some other stuff, so it's something that can just be added in along with the "normal" work.
'80 Isuzu LUV, 3" BL, cranked t-bars, small tires and not alotta power
'92 Rodeo...work in progress
Hmmmm...DIRT!!!
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.5886 MB (Peak: 0.6381 MB) Data Comp: Off Server Time: 2026-06-07 08:33:13 UTC
