Replacing the alt #708909 03/22/06 04:57 PM
TrooperChris Offline OP
Ok, so as soon as I can I am planning on taking my old alt out to have autozone check it. However, I believe it is bad. Dash lights are on, trouble starting, draining battery, etc.
Question is this...how hard of a replacement is this? Of course I am going to put a bigger one in <img src="/forums/images/graemlins/kewl.gif" alt="" />. I know it isnt a direct bolt in, and I have read some of the articles. BUT, if you have upgraded your alternator in your 2.6 please share some of your story as I like to have all info possible!
Would this be a better setup to run lots of lights and maybe a wench off of? Or do I need 2 batteries connected to this bigger alt?
TIA,
Chris
1988 Trooper: 2.6L Delta Cam, Pacesetter Header, K&N, 2 1/4 exhaust, CB, Lights by Hella, Warn Hubs, 6.5 inches of lift thanks to DOR and PA, Rancho 9000x's, 33X12.50 Durango MTs
1995 Nissan Maxima...the DD :-)
Re: Replacing the alt [Re: TrooperChris] #708910 03/22/06 07:25 PM
jdobbsj Offline
Man!! Spring fever has everyone on the alt kick these days.. I was just asking some questions within questions recently.. Here is the post. Follow the links within the link to see how Phil and Richard did there (and I will do mine).
http://www.4x4wire.com/forums/showflat.php?Cat=&Board=UBB68&Number=862254
88 Pickup,4x4, 2.6 L, AMC head, K&N Air filter, Aisin Hubs, Redline Oils everywhere, 94 Trooper wheels.
Re: Replacing the alt [Re: TrooperChris] #708911 03/27/06 10:08 PM
Smiley Offline
Chris - Just tell the fine folks at AlterStart that you want them to build a high-output version of this one for your Trooper. --- It'll bolt right up, and have plenty of juice to run ALL of those lights that you showed me (and then some!) <img src="/forums/images/graemlins/kewl.gif" alt="" />
<img src="/forums/images/graemlins/smile.gif" alt="" />
Six Isuzus, so far... still have three of them.
PHP: 7.4.33 Page Time: 0.009s Queries: 15 (0.007s) Memory: 0.5914 MB (Peak: 0.6453 MB) Data Comp: Off Server Time: 2026-07-13 09:34:43 UTC
