If I understand you right, you are saying that while in gear (any gear), moving or not, when you let your foot off the clutch pedal and try to get moving, the RPM's can rev up but not move the vehicle accordingly? A slipping clutch is a bit analagous to being on ice/snow in which you can gun the gas pedal while moving or still but the truck doesn't move accordingly (although in that case the tires are spinning on the ice).
If that's the case, you are probably due for a clutch replacement as the others have mentioned. Air in the hydraulic lines would have the opposite affect in which pushing on the clutch pedal does not release the clutch. There's always a chance the master or slave cylinders are sticking and not letting the clutch fully reseat again. There are no adustment mechanisms in the clutch system. How many miles does your truck have? When was the clutch last done?
If you do it yourself, you can get a complete clutch kit (don't get a remanufactured kit) from a local parts store for under $200. Make sure it comes with the clutch disk, pressure plate, throw-out bearing, pilot bearing, and plastic alignment tool. Regarding tools, you'll need a tranny jack, or a floor jack with some bracing to cradle the transmission/transfercase to lower them down. You'll need a torque wrench for putting things back together, and the pesky part of the job (for me) is removing the old pilot bearing. Also, remove the flywheel and have it resurfaced while it is out. Resurfacing will likely be around $30. Also get some locktite. You'll need it for the flywheel bolts and pressure plate bolts. My personal favorite clutch to use is the Centerforce Dual Friction set. While it's a bit more money, it's got a million mile guarantee and is great for those of us with larger tires etc, and the stiffness or amount of force it takes to push in the clutch pedal is the same as stock (I've installed 3 centerforce dual friction clutches).
While it's not hard, I wouldn't say I enjoy it either. The other part of the job that is a bit pesky is loosening the top two "tranny-to-engine-block" bolts. I end up using 3 or 4 socket extensions to get up there. On vehicles with body lifts, I can get to these 2 bolts from the engine bay.
I've never "roasted" a clutch, but have had a few fail due to old age and just start slipping as you mentioned (and there hasn't been any odor).
