oil splatter inside front fender wall #708980 03/22/06 10:50 PM
A
Andy_92563 Offline OP
It seems like I have a small leak in the front passenger side fender wall. It is not a major leak, it looks like a straight line trail of oil close to the outer fender. Anyone had similar problems? Thanks in advance.
-Andy
1999 Tacoma Black Limited V6, 4x4,104K,LEER shell cover, deck plate air box amsoil air/oil filters w/ amsoil fluids, bilsteins shocks front & rear
3" toytec coils & AAL, 4 new TOYO tires (31x10.5x15). selling truck to the right price!!
Re: oil splatter inside front fender wall [Re: Andy_92563] #708981 03/23/06 12:59 AM
W
Whizkidder Offline
Is the straight line of oil all the way around the inside of the fender -- like it's being thrown off the wheel as it turns? Or is it a line of oil running down the front or rear side of the wheel well?
Not much there to leak oil or grease farther out than the inside of the wheel -- I'd guess it might be something you picked up off the road unless it keeps coming back in the same place after you clean it off.
Re: oil splatter inside front fender wall [Re: Whizkidder] #708982 03/23/06 05:25 PM
ralleyclimber Offline
Blown shock or strut? It has been a while sense mine blew and I dont remember how much or where the oil from the shock/strut went in the wheel well.
Re: oil splatter inside front fender wall [Re: Whizkidder] #708983 03/24/06 12:05 AM
A
its a straight line of oil all the way around the inside of the fender -- like it's being thrown off the wheel as it turns. I just replaced all 4 struts and have no clue as to where its coming from though.
-Andy
Re: oil splatter inside front fender wall [Re: Andy_92563] #708984 03/24/06 05:56 AM
kewlynx Offline
That sounds like a split CV axle boot to me; those will sling grease pretty well once they're wide open. The how-to for replacing is in our maintenance section here.
Crawl under there and see what you find.
**ubi apis- ibi salus**
Re: oil splatter inside front fender wall [Re: kewlynx] #708985 03/24/06 06:02 AM
azrain Offline
I was thinking that or a leaking seal at the diff running down the prop shaft. Ditto on the visual inspection, only way you will be able to begin the diagnosis.
Mike
Re: oil splatter inside front fender wall [Re: azrain] #708986 04/03/06 07:21 AM
A
thanks for your replies, will definitely check it out first, cv boot does not seem cracked nor torn. will check and keep you guys posted. thanks.
-Andy
PHP: 7.4.33 Page Time: 0.016s Queries: 15 (0.010s) Memory: 0.6187 MB (Peak: 0.6927 MB) Data Comp: Off Server Time: 2026-11-16 08:40:00 UTC
