FJ80 rod ends?
#709080
03/23/06 02:41 AM
my question is will the FJ80 tie rod ends that marlin sells fit a stock tie rod from an 84' pickup? it says that they are used on cross over set ups on pickups and 4-runners, but it also says that the threads are up to 6mm larger in diameter then stock. does this mean you have to order one of their tie rods to use these ends or will they fit a stock tie rod? i would e-mail marlin directly but for some reason my computer wont let me.
thanks, jared
87' ext cab toy
Re: FJ80 rod ends?
[Re: lethe]
#709081
03/23/06 02:43 AM
Toyota Moderator
does this mean you have to order one of their tie rods to use these ends or will they fit a stock tie rod? They will not fit the stock tie rod, they are larger. You will need to order stock replacements or get a new tie rod.
Re: FJ80 rod ends?
[Re: DirtyHarry]
#709082
03/23/06 03:00 AM
where can you order stock replacements from? thanks for the quick reply
87' ext cab toy
Re: FJ80 rod ends?
[Re: lethe]
#709083
03/23/06 03:10 AM
nevermind, napa has em' for $32
87' ext cab toy
PHP: 7.4.33 Page Time: 0.009s Queries: 15 (0.006s) Memory: 0.5997 MB (Peak: 0.6552 MB) Data Comp: Off Server Time: 2026-10-24 02:34:07 UTCValid HTML 5 and Valid CSS
