Code 14, Igniter probs #709553 03/24/06 07:13 AM
Jickle Offline OP
I own a 92 pickup, 203k , v6, xtra cab auto.
The check light did not come on, just when I jumped the connectors. I got a code 14 when not running and running.
I read in the forums to check the voltage between E1 and Ig connectors and I got a 13.5v reading. (It should be between 0.7 and 1.0 v I believe)
I then checked the specs on the igniter and found out something interesting. I tested the igniter about 20-30 minutes after driving the truck and it says the ohm should be within .45 - .66 ohms when hot. Cold was like .33 - .55ohm I was getting a fluctuation between 0.4 to 0.9 ohm and even 1.0 once. WHAT THE HECK ? Should I replace the igniter?
The engine runs fine, except for a slight hesitation when starting. There is a slight variance in the rpm when idling. What should I do, the voltage is WAY off of what is should be. The engine has never stalled on me.
Thanks ahead of time !
stock 92 pickup, v6, xtra cab, 4x4 IFS, 204k miles
Re: Code 14, Igniter probs [Re: Jickle] #709554 03/24/06 09:03 AM
The increased resistance shows the effects of heat on the coil. Try resetting the CEL by pulling the EFI fuse or disconnecting the negative battery terminal for about 10 minutes. It mayhave been a false code.
The surging at idle may be a small vacuum leak or the TPS a little out of adjustment ( or not working properly).
Mike in AR
PHP: 7.4.33 Page Time: 0.009s Queries: 15 (0.007s) Memory: 0.5862 MB (Peak: 0.6358 MB) Data Comp: Off Server Time: 2026-11-16 01:24:12 UTC
