long travel suspension kit with previous lift kit #709663 03/24/06 08:28 PM
P
philly Offline OP
i've been looking into long travel suspension kits alot lately, i like the total chaos caddy kit, and i am wondering if anyone has ever put a long travel kit on a 4 inch procomp lift, i've heard its been done but haent found anything about it yet, i am debating on an sas or long travel kit. thanks
Re: long travel suspension kit with previous lift kit [Re: philly] #709664 03/24/06 08:47 PM
Seldom_Seen Offline
Off Road Solutions has done one
Belongs to a member here engxnerd send him an email or check out ORS's web site
Re: long travel suspension kit with previous lift kit [Re: Seldom_Seen] #709665 03/24/06 09:15 PM
Jake97T Offline
im in the process of installing a total chaos gen 2 kit on my T100, problem with stacking a lift kit is first your center of gravity will be rediculously high...the spindle can handle one lift kit at a time, putting on a second lift will put alot of stress on your truck, youll be more likely to bend your control arm mounts with a drop bracket lift and longer control arms.
The other thing about the torsion bar lift is broken torsion sockets and ripping the upper control arm mount off the frame.
Your body roll is going to be really bad with 2 lifts, especially since you cant use a sway bar with the total chaos kit, however ill be using one on the rear...my superlift is coming off and then i plan on just doing about 4" lift with the coilover kit and 3" in the rear with some chevy springs. Total chaos probably wont cover them under their product liability insurance either if you set it up like that.
Re: long travel suspension kit with previous lift kit [Re: philly] #709666 03/25/06 02:45 AM
Kaptain Offline
SAS or long travel kits really depend on what kind of
wheeling your into. Ideally a SAS would be the best
choice for many reasons. <img src="/forums/images/graemlins/kewl.gif" alt="" />
93' Toy xCab
bobbed > 22rEB > w56 > stock duals > SAS > 4.88's > 37's
Re: long travel suspension kit with previous lift kit [Re: Kaptain] #709667 03/25/06 06:33 AM
Jake97T Offline
i enjoy speed but also enjoy the rocks, id like a SAS too but im going to have to wait for a mini toy for that. Definetly stay away from stacking lifts do a SAS, alot cheaper over all too.
Re: long travel suspension kit with previous lift kit [Re: Jake97T] #709668 03/25/06 07:30 PM
ErikB Offline
Toyota Moderator
It should work fine. Scott @ Rockstomper ran basically the same thing on his truck for years. I considered doing the same thing too before I SAS'ed.
http://toyota.off-road.com/toyota/article/articleDetail.jsp?id=305949
I wouldn't recommend using the long travel kit as an extra lift kit though (or at least not much). Use the lift for ground clearance and tire clearance, and the long arm kit for the long travel. That's basically what Scott did too. Notice in the pics that his control arms are still relatively flat.
http://home.4x4wire.com/erik
PHP: 7.4.33 Page Time: 0.012s Queries: 15 (0.010s) Memory: 0.6100 MB (Peak: 0.6804 MB) Data Comp: Off Server Time: 2026-07-14 12:26:09 UTC
