pilot bearing woes #709770 03/25/06 03:52 AM
dewmtndew Offline OP
My buddy and I are changing the clutch on his 93 v6 pickup and we cannot get the pilot bearing out. We started with a headbolt and some grease, but the covers werent on the bearing anymore and the grease went right through the bearing. We tried a homebuilt slide hammer with a big ol socket and that didnt make it budge either. Now we have a pilot bearing removal tool and that doesnt work either, the arms bend and the bearing doesnt budge....We've been spraying it with wd-40 with no help. Please help us out!
thanks in advance
erick
85 Pickup
33s, lift, EB cam, header, exhaust...
Re: pilot bearing woes [Re: dewmtndew] #709771 03/25/06 03:54 AM
kewlynx Offline
Start packing some wet newspaper in there with a dowel.
Good luck!!
**ubi apis- ibi salus**
Re: pilot bearing woes [Re: kewlynx] #709772 03/25/06 10:18 PM
Well, we ended up cutting it out, I am still amazed how tight that thing was in there, Ive never had trouble getting one out. thanks margie for your quick response
erick
85 Pickup
Re: pilot bearing woes [Re: dewmtndew] #709773 03/26/06 04:37 AM
87Toy4x4 Offline
pb blaster also works a lot better at stuff like that than wd40. i used the grease packing method and dowel to remove mine, and one on a 4runner.
Re: pilot bearing woes [Re: dewmtndew] #709774 03/26/06 06:46 AM
kewlynx Offline
Welcome; what did you guys use to cut it out with? Curious; I've been pretty lucky in the past with these.
Re: pilot bearing woes [Re: kewlynx] #709775 03/26/06 07:09 AM
J94_4runner Offline
2nd the PBLaster. makes WD40 look like Shizi.
www.celicasupra.com
Re: pilot bearing woes [Re: J94_4runner] #709776 03/26/06 11:17 AM
Where do you get pb blaster???? Ive never seen it around anywhere.
margie, We used a dremel and the small size cutting discs. we made some nicks in the crank, but nothing to major. After that it came out with no effort.
erick
85 Pickup
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6198 MB (Peak: 0.6932 MB) Data Comp: Off Server Time: 2026-06-07 07:16:21 UTC
