looking for bed bob write ups
#710339
03/27/06 05:29 AM
ok iv looked and ive found a few but there hase to be more out there. im gona make the chop probably this week and wanted all the info i can. any write up links or advice would be nice
and any info on how to reenforce the bed bottom would be helpfull as well not from rust i have none of that but from overloading it to close to the end one big break althe way across right behind wheel wells
oh im choping an 85 xcab box back to the shackle mount
Re: looking for bed bob write ups
[Re: BJWEST]
#710340
03/27/06 05:38 AM
'84 PU low & slow Central Valley Crawlers
[Re: Talon84X4]
#710341
03/27/06 05:42 AM
[Re: BJWEST]
#710342
03/27/06 05:51 AM
[Re: MnMsToY]
#710343
03/27/06 05:54 AM
thanks i have a hard time on pirate cant ever find anything
[Re: BJWEST]
#710344
03/27/06 05:55 AM
As for ideas on reinforcing the frame i've seen angle iron welded along the bottom of the box on the areas of interest, don't remember exactly which direction it was going as far as along or across the grooves
[Re: Talon84X4]
#710345
03/27/06 06:00 AM
As for ideas on reinforcing the frame I didn't reinforce anything. Holds strong and I cut a little over 13 inches on my Longbed. Mike
[Re: Talon84X4]
#710346
03/27/06 06:03 AM
You can take and cut 4-5 inch piece of the bed bottom and sides and use it underneath the bed and inside the fenders to use as a backing. Makes it much easier to weld up without blowing holes it it as easy. Spot weld it in place about every 5-6 inches.
"Serenity through Sobriety"
[Re: OOP'S]
#710347
03/27/06 06:06 AM
[Re: MnMsToY]
#710348
03/27/06 06:09 AM
I didn't reinforce anything. Holds strong and I cut a little over 13 inches on my Longbed. Mike reenforcing a bed width crack further foward than the bob
PHP: 7.4.33 Page Time: 0.014s Queries: 16 (0.010s) Memory: 0.6386 MB (Peak: 0.7619 MB) Data Comp: Off Server Time: 2026-11-16 01:26:58 UTCValid HTML 5 and Valid CSS
