3.4 engine swap #710384 03/27/06 09:40 AM
N
nateyesme Offline OP
Im planing on getting a new engine for my truck because my 3.0 shot two rods out. Everyone says to just do the 3.4 swap. I found an offroads solution kit for around 1700 and I can get a brand new 3.4 engine from jasper for 4000. But I'm woundering how hard the swap would be. the only car I've ever done a swap on is a 1972 dodge dart. Does anyone know If the wiring is a pain in the butt..
Re: 3.4 engine swap [Re: nateyesme] #710385 03/27/06 06:32 PM
DirtyHarry Offline
Toyota Moderator
Not if you buy the harness from Off Road Solutions, they are custom made to each order. It makes the swap a plug-and-play affair. Since you retain the stock radiator, transmission, etc, this is one of the easier motor swaps you can do.
Re: 3.4 engine swap [Re: nateyesme] #710386 03/27/06 10:08 PM
Frank Torres Offline
Check with Jasper your motor may only be a short block...
but for 4 grand they might just throw in everything...hope so for the price.
How about a used motor with low miles?
1991 FJ 80 Land Cruiser for fun.
1998 GS300 for the wife
1998 GS400 for me
1991 Supra SOLD
1986 4Runner 335k miles-22re EB inside.SOLD
Re: 3.4 engine swap [Re: nateyesme] #710387 03/27/06 10:31 PM
G
Greg_Canada Offline
Jasper is just the long block prob, you will still need valve covers, intake, exhaust, computer, wiring harness, EVERYTHING...
89 4Runner
Re: 3.4 engine swap [Re: Greg_Canada] #710388 03/27/06 11:01 PM
Jake97T Offline
there are some 3.4L motors for sale out there, most of them ive seen are out of California, expect to pay about $2k on a used 3.4L, check with some junk yards on the motor, public auctions sometimes can get you a totalled tacoma or 4runner for a few thousand with a motor in it.
Re: 3.4 engine swap [Re: nateyesme] #710389 03/28/06 06:03 AM
CORunner93 Offline
The wiring is kind of a pain.....but not enough of one to get me to shell out $700 for the ORS conversion harness. But, the ORS harness would make things go a LOT quicker and easier.
'93 4Runner - 3.4L 5VZ-FE, 2" body lift, on-board-air system, custom gauge cluster, rear e-locker, electric fan, custom built front and rear bumpers, sliders, 4,88 gears...all on 33x12.5's.
Re: 3.4 engine swap [Re: CORunner93] #710390 03/28/06 03:03 PM
mt_goat Offline
Hey CO, did you get the AC going in your swap?
93 4X4 ext-cab, auto, SR5, 3.4 V6, supercharged, 2.1" pulley, URD fuel mods, Aquamist WI, IPT valve body mod, dual cases, 4" superlift, Alcan springs, 33 BFG MT, ARB locked front & rear, 5.29 US Gears, RB 1" BL, 1.5" BJ spacers, TJM T-17, Warn m8000.
Re: 3.4 engine swap [Re: mt_goat] #710391 03/29/06 04:22 AM
CORunner93 Offline
Not yet. I still need to lengthen one of my AC hoses coming from the compressor and get the thing recharged. that's another spring project, I need to get to.
Re: 3.4 engine swap [Re: CORunner93] #710392 03/29/06 02:42 PM
mt_goat Offline
Are you using the 3.4 AC lines or the 3.0 lines?
Re: 3.4 engine swap [Re: mt_goat] #710393 03/30/06 04:56 AM
CORunner93 Offline
I'm using the whole 3.0L system...lines and compressor, all I did was change the pulleys....the 3.0L haa a "V" belt, 3.4L has a serpitine belt.
PHP: 7.4.33 Page Time: 0.010s Queries: 16 (0.006s) Memory: 0.6370 MB (Peak: 0.7591 MB) Data Comp: Off Server Time: 2026-11-02 07:43:10 UTC
