Jack points? #710483 03/27/06 05:35 PM
wademan Offline OP
Can anyone help me with an good illustration of preferred jack points (just for tire rotation) for 2002 4WD? I'd really appreciate it!
02 Taco 4x4, V6, TRD
Re: Jack points? [Re: wademan] #710484 03/27/06 06:36 PM
hupptoy Offline
What kind of jack are you using?
If you are using a floor jack, then you can lift the rear using the center of the rear axle. For the front, i usually try to use a flat spot on the front suspension to lift with (helps if your jack has a rubber pad on the saddle...). And I hope you have a pair of jack stands to make everything easier.
hupptoy
99 4Runner SR5 3.4 Auto 4x4, 32" LTX A/T, 154K
93 Toy x-cab 22RE 5-spd 4x4, 31" LTX A/T, 150K
Re: Jack points? [Re: hupptoy] #710485 03/27/06 06:40 PM
lethe Offline
like hupptoy said for the rear you can jack it up from the pumpkin, but i would definatly(sp?) put jacks on each side of it. at work when i jack up ifs trucks i use two jacks on the ifs crossmember. if you live near a discount/americas tire co they will rotate your tires for free.
nevermind, i dont think we have an stores in penn. but i could be wrong <img src="/forums/images/graemlins/confused.gif" alt="" />
87' ext cab toy
Re: Jack points? [Re: lethe] #710486 03/28/06 08:50 PM
Speaking of jack points, I do a fair amount of exploring off road and the factory jack barely works on pavement. I have a high lift which works fine on the rear bumper but as for jacking the front the truck - forget it.
Questions -
1. I have never actually used the high lift on the rear bumper. Does the lifting nose on the jack work safely with the stock Taco bumper or do you need the bumper lift accessory?
2. What do you think is the best way to go for the front - replace front bumper or get sliders strong enough to lift the truck? I don't want to weld on my frame but I have heard that the bolt on sliders can support the truck. Is there any other cheaper alternative?
Thanks
Re: Jack points? [Re: hupptoy] #710487 03/29/06 12:24 AM
G
Greg_Canada Offline
Ummm... i'd only use a highlift on a tube style bumper, or on a reciever hitch... me thinks it will tear open a stock bumper like a tin can...
Rock sliders (NOT nerf bars) can be hi-lifted using a round tube adaptor... o relse they can slide off pretty easy...
89 4Runner
Re: Jack points? [Re: Greg_Canada] #710488 03/29/06 06:46 AM
you can hilift off the back bumper all day long
as for the front well you should get one of THESE
Re: Jack points? #710489 03/29/06 06:49 AM
Re: Jack points? [Re: wademan] #710490 03/29/06 07:03 AM
kewlynx Offline
From the FSM stickyd here:
LINKY You'll see the JACK article below in the sidebar.
**ubi apis- ibi salus**
Re: Jack points? [Re: kewlynx] #710491 03/30/06 07:22 PM
That's a great jacking description but as I remember the OEM jack barely lifts a stock 4x4 high enough. With even a minor lift I don't think it can lift the tire. Anything other than pavement under the jack is asking for trouble.
(Although if you want to get technical the lift makes no difference since the relationship between the jacking point and hub/axle has not changed at max droop but a larger tire will make it more difficult)
Re: Jack points? #710492 03/31/06 03:04 AM
kewlynx Offline
I fabbed up a couple of these to go with my upgraded bottle jacks for my 'other' trucks.
http://www.4x4wire.com/toyota/minutemods/hilift_base/
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6239 MB (Peak: 0.7315 MB) Data Comp: Off Server Time: 2026-06-21 17:51:51 UTC
