Headlights won't turn on. #710629 03/27/06 09:36 PM
Paul Elbisser Offline OP
working fine, went into store. when I came out they wouldn't come on. No High low flash, nothing but taillights. SO I put a hot wire from the 80a fuse, to the comon on the headlight and they came on, drove it home. High and low both worked then.
I tried new relay, it didn't help. Jumpered the relay, and they come on.
I now have the column apart and the switch off. It seems to be working Put an ohm meter on the plug between the small red and both whites.
Anyone have a clue where my grounds may be for this? That seems to be the next likely step.
Paul Elbisser #3233
pastTLCAEastern Rep.
Pres Rice on the Rocks
www.riceontherocks.org
Re: Headlights won't turn on. [Re: Paul Elbisser] #710630 03/27/06 10:06 PM
4Crawler Offline
Headlight/combo switch perhaps:
- http://www.4crawler.com/4x4/CheapTricks/Headlights.shtml#Headlight_Combo
Cab ground is in the driver's side kick panel area, bolt into the floor w/ a bunch of brown wires tied to it.
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.5893 MB (Peak: 0.6374 MB) Data Comp: Off Server Time: 2026-06-07 02:28:37 UTC
