Wheel Lock? #710660 03/27/06 11:37 PM
koolaid6666 Offline OP
How do I remove the wheel lock On My Montero? It has the factory Spare tire Still On the Back Never used. I figured let me check It case I get A flat tire. I'm not the original Owner. It's on there pretty Good
2003 Montero Limited White
2001 Montero GLS Diesel
1990 Montero Black Off Road Package.
1990 Montero Parts Truck.
Re: Wheel Lock? [Re: koolaid6666] #710661 03/28/06 12:46 AM
LRJ4x4 Offline
You can try a tire place and see if they have a key. When I bought my truck I had the same problem both with the spare and a Locked on Yakima rack. Luck for me I have a friend named "Jerry's Machine Shop" the lock was no match for the air chisel <img src="/forums/images/graemlins/mrt.gif" alt="" />
Re: Wheel Lock? [Re: LRJ4x4] #710662 03/28/06 01:11 AM
That wheel lock key should be available at any wheel/tire place. Its a verry common lock. Its what they sell as lugs with most aftermarket rims. Not much of a lock anymore because everyone has the key. I have one out in the shop.
Re: Wheel Lock? #710663 03/28/06 04:00 AM
Low tech, and might wreck the nut, but some stilsons (pipe wrench) would work ok?
Re: Wheel Lock? #710664 03/28/06 05:39 AM
52degrees Offline
I have a special tool for removing those things. The locking nut is pretty much useless when it comes off, but it does come off. I bought it on the Mac truck back when I could find a Mac truck <img src="/forums/images/graemlins/rolleyes.gif" alt="" />
I'm pretty sure a Snap-On truck would have something.
Clay
KG6VNX
Re: Wheel Lock? [Re: koolaid6666] #710665 03/28/06 12:58 PM
P
pcc Offline
Try checking in the jack compartment for the key, that's where I keep mine, in the plastic resealable bag that the locks came in. Could also be in the compartment on the PS as well. No reason for the previous owner to loose it.
Re: Wheel Lock? [Re: pcc] #710666 03/28/06 06:47 PM
4xmonty Offline
There are basicly Twelve keys for the mitsu locks.They are
coloer coded.If you go to a Mitsu dealer they have a set
of all twelve that they let you use to find out what color/key you need for a replacement.if you dont have the locks on your rims you might be able to talk them into
letting you use the set to take your spare lock off.Check
with the parts dept.I know this because I had to get another key.
Russ <img src="/forums/images/graemlins/kewl.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" /> <img src="/forums/images/graemlins/patriot.gif" alt="" />
GETTIN OLD THATS EARNED
Happy trails to you
(1)98 Montero SR RB Rock Crawlers BFG 33s Rancho 9000's OME Med coils rear
(2)95 4Runner All Pro Nerf bars BFG 32s
ARB bull bar
Downey 2" rear coils Downey headers
(3) 90 Montero LWB 3.0 auto
(4) 98 Kawi GPZ1100
Re: Wheel Lock? [Re: 4xmonty] #710667 03/28/06 08:26 PM
JunkIt Offline
Ya'll are gettin' fancy with your keys... I just used a 12 point socket (I think it was 11-12mm...not sure, was 3 years ago), banged it on with a BFH <img src="/forums/images/graemlins/shiner.gif" alt="" /> and then proceeded to remove the lock nut. Put socket in vice, knock out nut with BFH, repeat <img src="/forums/images/graemlins/smile.gif" alt="" />
Re: Wheel Lock? #710668 03/28/06 08:59 PM
grass13 Offline
yup... done a couple like that. pointless to try to save it if you dont have the key, and it dont cost anything.
Re: Wheel Lock? [Re: grass13] #710669 03/29/06 12:08 AM
PartyTruck Offline
If the pipewrench doesn't work just weld a socket on it.
1987 SWB Pajero 2.5 TDI on 31" rubber waiting for a hip replacement and bigger shoes
PHP: 7.4.33 Page Time: 0.017s Queries: 16 (0.012s) Memory: 0.6368 MB (Peak: 0.7560 MB) Data Comp: Off Server Time: 2026-11-18 22:08:03 UTC
