Page 1 of 3 1 2 3
axle vents #711051 03/29/06 12:06 AM
maxxis85 Offline OP
Are those little things sufficeint enought to keep water out my diffs if ran through mud/ water. Inoticed I dont have tubes like on a chevy. I have an 89 toyota pickup.
1989 TOYOTA PICKUP 4"trailmaster, 3" Body Lift 8,000 lb warn winch, q-78 tsl super swampers
Re: axle vents [Re: maxxis85] #711052 03/29/06 12:19 AM
DirtyHarry Offline
Toyota Moderator
Nice looking truck. You can use the fitting off a Celica intake manifold (PN 90404-51319) as shown in this article .
Re: axle vents [Re: DirtyHarry] #711053 03/29/06 02:52 AM
87Toy4x4 Offline
all 22re's have the same vent on them also. i think its for the pcv valve. im not sure. i usually grab them off motors at the junkyard if i see them.
Re: axle vents [Re: maxxis85] #711054 03/29/06 03:36 AM
OOP'S Offline
No, you need to extend them. If you cannot find the barbs listed below you can use a 1/8" NPT brass barb. The threads are almost the same and the brass is soft enough that the steel housing will cut threads. I screw then in first cutting the threads, then pull them back out and wrap the threads with Teflon tape.
David Fritzsche
Roseville, CA
"Serenity through Sobriety"
Re: axle vents [Re: OOP'S] #711055 03/29/06 03:58 AM
maxxis85 Offline OP
so just poppin the caps off the stock ones and putting a hose to the bed wouldnt be sufficeint? Oh And is the vent the same for the IFS 7.5" front differential
Re: axle vents [Re: maxxis85] #711056 03/29/06 04:41 AM
87Toy4x4 Offline
you can use the same barb for the front but it will hit your oil pan. but if you have a suspension lift i dont think it will.
Re: axle vents [Re: 87Toy4x4] #711057 03/29/06 04:50 AM
maxxis85 Offline OP
So get the nissan vents and run tubes to engine bay will work. Yes i have a sus lift. And the stockers arent an ootion here? Im not trying to be cheap either. Just curious that all, cuz this needs to be done
Re: axle vents [Re: maxxis85] #711058 03/29/06 04:57 AM
87Toy4x4 Offline
you dont need nissan ones. it would be easier to just go grab some vents off of a 22re. or you can get them from the dealer. i dont have the p/n right now but im sure someone on here does.
Re: axle vents [Re: 87Toy4x4] #711059 03/29/06 04:17 PM
maxxis85 Offline OP
What vents are you talking about man. Is it off the motor, and where are they located so i can grab some? Last 22r i seen was my dads 83 hilux and i was a kid that doesnt know what that was
Re: axle vents [Re: maxxis85] #711060 03/29/06 05:33 PM
4Crawler Offline
Page 1 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.010s Queries: 16 (0.005s) Memory: 0.6446 MB (Peak: 0.7645 MB) Data Comp: Off Server Time: 2026-10-24 08:16:03 UTC
