Page 2 of 3 1 2 3
Re: axle vents [Re: 4Crawler] #711061 03/29/06 06:56 PM
BJWEST Offline
the stock ones work well but go bad arter 15 or 20 years in my case. trail gear sells brand new stock ones for under ten bucks
Re: axle vents [Re: maxxis85] #711062 03/29/06 07:00 PM
LUV24BY Offline
IMHO pop the cap off, put a hose on it and a clamp and run it under your bed. I used clear hose rather than black so if I had concern I can look under and see if there is moisture within the tube itself. Make sure you run the tube in some sort of upside down 'U' so water doesn't go in easily. I got my tubing from ACE hardware.
John
This is my first time here, be gentle......
.....But play DIRTY!
1985 Toyota 4Runner
http://www.cardomain.com/ride/2066809 Check this if you want to see her!
Re: axle vents [Re: LUV24BY] #711063 03/29/06 11:07 PM
CheviHemi Offline
...Make sure you run the tube in some sort of upside down 'U' so water doesn't go in easily. I got my tubing from ACE hardware...
Won't you run the risk of creating a siphon using the upside down "U" shape? If water does start to go into it and peaks the crest it will fill pretty quickly I would think...
Red 1996 S10 Zr2 (Semi-Retired Wheeler)
'84 Toyota on 36's (Project in the Making)
Re: axle vents [Re: CheviHemi] #711064 03/29/06 11:34 PM
87Toy4x4 Offline
i used a factory breather from toyota that has a barb on it. it looks exactly like the stock ones on the axle but has a barb on the end. i ran mine into my gas cap filler. ill try and get pics today for you.
its one of the two breathers i circled. youll be able to know which one it is in person by looking at it.
Re: axle vents [Re: 87Toy4x4] #711065 03/29/06 11:48 PM
87Toy4x4 Offline
haha sorry for the big pic. i had no idea it was going to be like that. but im pretty sure its the left one i circled now.
heres a pic of what my breather looks like from the back. this was when i was putting my rear locker in and my truck was really muddy.
Re: axle vents [Re: CheviHemi] #711066 03/30/06 01:22 AM
LUV24BY Offline
Not necessarily - to my knowledge. I would think that there isn't any 'suction' coming from the diff. Hence if you leave a big enough upside down U unless your parked in the water it's not going to 'sciphon' in the water!
John
1985 Toyota 4Runner
Re: axle vents [Re: LUV24BY] #711067 03/30/06 02:05 AM
DirtyHarry Offline
Toyota Moderator
There is a common theory that hot gear oil and the air in the diff from the spinning gears will become instantly cooled upon the housing's contact with cold water. The cooling will cause the air and gear oil to contract and air gets sucked in. That is why the diffs aren't completely sealed to begin with.
Re: axle vents [Re: DirtyHarry] #711068 03/30/06 03:57 AM
maxxis85 Offline OP
Thanks to all who chimed in I'll see what i can find this weekend because im going to a ride on april 9th so i want to be ready. This weekend is going to be fun, replace cv's and repack front wheel bearings.
1989 TOYOTA PICKUP 4"trailmaster, 3" Body Lift 8,000 lb warn winch, q-78 tsl super swampers
Re: axle vents [Re: maxxis85] #711069 03/30/06 08:06 AM
4WD22R Offline
You can see where my breather goes into the top of the pumpkin there....
And one over all.....
Ignore those blingin red coils <img src="/forums/images/graemlins/smile.gif" alt="" /> <img src="/forums/images/graemlins/smile.gif" alt="" /> I used the fitting from the stealer. P/N:90404-51319
-1986 TOYOTA
22R
ZUK coil rear
Torqued T-Bars
Marlin HD clutch
AZTTORA #492
TLCA member
"I hear there's rumors on the Internets that we're going to have a draft."
--George W. Bush
Re: axle vents [Re: 4WD22R] #711070 03/31/06 05:02 AM
BRreddog Offline
I used 1/8 NPT hose barbs. In the back I ran the hose up by the tail light housing. In the front I zip tyed it up near the carb. If I find water that deep my K&N will be under anyway. I got the barbs from McMaster Carr, a ten pack, pretty cheap.
'86 22R Bored .080", Stroked 5.5mm, LC header, Downey 2.25" SS exhaust, 33" SST Coopers, 4W disk brakes, T-Case brake, PRP Seats
Page 2 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.008s Queries: 16 (0.005s) Memory: 0.6452 MB (Peak: 0.7673 MB) Data Comp: Off Server Time: 2026-06-17 04:16:48 UTC
