Shaw need's help with front IFS axle replacement #711399 03/30/06 04:26 PM
BobShaw Offline OP
I am going to replace my rusty Left front axle with a better one from Calif. Don't I neeed to loosen a ball joint to get the spindle to pivot more to get clearance to remove the axle?
Do I loosen/remove the upper or lower ball joint? Don't I also need to remove the outer tie rod end?
I just replaced the right side axle. I was pleased with the wear of the needle bearing I had replaced with a tube of delrin.
If I use a lift, do I need to loosen the torsion bar too.
The needle bearings only hold up for 2 years. The delrin was worn but still acceptable after 6-7 years of use.
Thanks for the help in advance. <img src="/forums/images/graemlins/confused.gif" alt="" />
Re: Shaw need's help with front IFS axle replacement [Re: BobShaw] #711400 03/30/06 04:37 PM
powerRam50 Offline
i had to pop the upper ball joint and tie rod.and loosen the torsion bar when i did mine.oh and on the left side i also had to pull the lower but i just did the 4 bolts that hold it to the lower arm.it is pretty easy.
Re: Shaw need's help with front IFS axle replacement [Re: powerRam50] #711401 03/30/06 05:02 PM
lordtrunks Offline
I just pop the upper and lower balljoints along with the tie pull the spindle off then its pretty easy.
89 2 dr turbo diesel
89/88 "Backwoods sas"
Re: Shaw need's help with front IFS axle replacement [Re: lordtrunks] #711402 03/31/06 01:48 AM
PHIL_ Offline
I did likewise. Upper and lower, tierod, yank the knuckle, and you're good to go. If you're using a balljoint splitter, have extra grease boots on hand. <img src="/forums/images/graemlins/rolleyes.gif" alt="" /> Or maybe I was just unlucky. <img src="/forums/images/graemlins/angry.gif" alt="" />
PHP: 7.4.33 Page Time: 0.010s Queries: 15 (0.008s) Memory: 0.6022 MB (Peak: 0.6583 MB) Data Comp: Off Server Time: 2026-07-13 16:07:10 UTC
