noisy power steering pump? #711434 03/30/06 11:22 PM
i have just replaced timing chain sprockets and belts etc.and when i got everything together i noticed an intermittent rattle from the power steering pump area.The idle pulley rotates with ease, took everything off and thought a little packing would do the trick but no avail. now its getting worse.Is there bearings inside the psp pump or pulley itself that would make the rattle noise.'86 2wd 22r ext cab with a long bed 164k. thanx for any help given <img src="/forums/images/graemlins/confused.gif" alt="" />
Re: noisy power steering pump? #711435 03/31/06 07:05 AM
4WD22R Offline
You might try to tighten the bolt in the middle of the pully, I know last time I changed belts, I forgot that one and it made a hell of a racket. Other than that I'd say it's time to R&R the pump, it ain't that hard, IIRC the pump kit is about $50 from the stealer.
-1986 TOYOTA
22R
ZUK coil rear
Torqued T-Bars
Marlin HD clutch
AZTTORA #492
TLCA member
"I hear there's rumors on the Internets that we're going to have a draft."
--George W. Bush
Re: noisy power steering pump? #711436 03/31/06 07:24 AM
kewlynx Offline
These might be a help:
http://www.4x4wire.com/forums/showf...07216&fpart=1&PHPSESSID=
http://128.83.80.200/taco/box.html
Also the FMS sticky'd here might be helpful.
**ubi apis- ibi salus**
Re: noisy power steering pump? #711437 03/31/06 07:09 PM
TheToeCutter Offline
If you decide to rebuild the PS pump here is a great direction guide with photos. Got it from someone else on this board.
http://members.cox.net/stacewilliams/ps-pump.htm
Re: noisy power steering pump? [Re: TheToeCutter] #711438 03/31/06 08:36 PM
Staceman Offline
Glad to see my site still running <img src="/forums/images/graemlins/pfft.gif" alt="" />
I'm sure yours is a 4 cyl. The site I made was for a 3.0 V6.
Knowing Toyota, I'll bet that alot of the same info would apply though. Good Luck.
Staceman
(aka, Stace Williams)
Re: noisy power steering pump? [Re: Staceman] #711439 04/01/06 05:02 AM
Opps yeah I didn't notice Jeddi wrote in his post it was a 22 RE engine. Sorry. I just found Staceman's guide so helpful I try to share it with people who ask about rebuilding the pump.
Re: noisy power steering pump? [Re: TheToeCutter] #711440 04/01/06 01:57 PM
ZUK Offline
jeddi--- My PS pump is noisy about once a week....I have a leaker and I just fill it up and she gets quiet again smile My ps fluid is always clean cause the new stuff goes in the top and the bad stuff leaks out the bottom. Maybe yours is simply low.
Staceman----so that's what it used to look like <img src="/forums/images/graemlins/cyclops.gif" alt="" />
(from your website posted above)
mostly stock
Re: noisy power steering pump? [Re: ZUK] #711441 04/01/06 09:19 PM
Staceman Offline
Yeah buddy, the first time she saw dirt after I picked her up in Tucson a few years ago. Pretty clean huh??
Here's a pic from 2 week-ends ago with the TTORA group. PS ZUK, the coils did great, alot of questions on those and my rear bumper. All camp gear didn't lower the rear end at all <img src="/forums/images/graemlins/kewl.gif" alt="" />
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.005s) Memory: 0.6235 MB (Peak: 0.7186 MB) Data Comp: Off Server Time: 2026-06-22 06:06:07 UTC
