new hubs #711551 03/31/06 09:56 AM
twholland Offline OP
Anyone used Mile Marker hubs? thinkin about picking up a set, but wasn't sure if they're any good. Also saw Superwinch and Warn(little more $$$) sets. I don't use 4wd very often, but i want to do the hub conversion for obvious reasons. Saw some used Aisins, but i dont feel like rebuilding them, so i'm willing to spend the extra few $$$.
What gaskets am i going to need for the swap?
'97 T100 XCab 4X4 SR5, 3" BL, 33x12.5 BFG A/T, Warn hubs, Ranchos
Re: new hubs [Re: twholland] #711552 03/31/06 12:36 PM
surlynkid Offline
feel like rebuilding. there is no comparison. AISIN is the way to go. just look for a nice set that is bolt on. pay for that instead of paying for another brand.
scott
Scott Landon
1990 Spec Miata
2010 GT3
2013 E92 M3
Re: new hubs [Re: surlynkid] #711553 03/31/06 04:17 PM
Jake97T Offline
front range offroad sells them for $50 if your working with ADD hubs...
Re: new hubs [Re: Jake97T] #711554 04/01/06 12:59 AM
4
4xGeek Offline
Haven't had any issue with my Warn, but they do stick out a lot farther than Aisin... Mine don't look so pretty anymore. <img src="/forums/images/graemlins/shiner.gif" alt="" />
4xGeek (Chris)
'97 T-100 4wd sr5-suto, 3" BL, 1.5" BJ spacers, 35" ProComp AT's, 4.88's, Bilsteins x 6, etc...
No longer stuck in SoCal!! smile
Re: new hubs [Re: 4xGeek] #711555 04/02/06 01:59 AM
urso8up Offline
1998 T100 4x4 3 body lift 4 procomp suspension 15x10 steel wheels and 35x12.50x15 Baja Claws
http://www.cardomain.com/id/urso8up
Re: new hubs [Re: twholland] #711556 04/02/06 03:43 AM
kewlynx Offline
I ditto Aisin; stay away from those MM's; they suck. We had a guy post once down in the vendors section who rebuilds Aisins, but I can't find/remember who he is now; might want to post up over in the OT section to see if you can get a nibble. Feedback is that he does a good job, and gives them a powdercoat.
If you can get a cheap set of Aisins anymore these days, you better jump on 'em and keep them as spares. <img src="/forums/images/graemlins/shame.gif" alt="" /> <img src="/forums/images/graemlins/shame.gif" alt="" /> Check what Marlin wants for 'em. <img src="/forums/images/graemlins/scared.gif" alt="" />
**ubi apis- ibi salus**
Re: new hubs [Re: Jake97T] #711557 04/02/06 07:12 AM
I'm going to pick up a set from front range. thanks for the input fellas. My second question still stands, What gaskets are needed for the job? I also read something about new cone washers "just in case"???
Re: new hubs [Re: twholland] #711558 04/02/06 07:30 AM
4
4xGeek Offline
The reason for new cone washers is simply in case you lose one, as they have a tendency of going flying & getting lost. Ask me how I know...<img src="/forums/images/graemlins/shiner.gif" alt="" />
I think it's just a single gasket... Anyone know the part #?
4xGeek (Chris)
Re: new hubs [Re: twholland] #711559 04/03/06 01:23 AM
surlynkid Offline
two gaskets. one between the two halves of the aisin hub and one where it mounts to the rotor/hub assembly. PM me if you need part numbers, and i can post tomorrow night. only loosen the nuts before whacking with a brass drift, so the cone washers cannot go flying across the garage.
Scott Landon
1990 Spec Miata
2010 GT3
2013 E92 M3
Re: new hubs [Re: surlynkid] #711560 04/03/06 05:20 PM
4
4xGeek Offline
Sure, now somebody tells me... <img src="/forums/images/graemlins/drunk.gif" alt="" />
4xGeek (Chris)
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6317 MB (Peak: 0.7389 MB) Data Comp: Off Server Time: 2026-05-29 23:56:53 UTC
