Pull under braking #711642 03/31/06 09:50 PM
Davis5210 Offline OP
Every time I go to brake my 95 4runner pulls HARD to right. The alignment is good and goes straight at a constant speed. It has a slight pull to the left under accelleration too. Steering feel is just bad in general. Im thinking there are some shot bushings. Is this possible? which bushings would be shot
1995 4runner SR5
PP rear springs
Hella FF1000 lights
31X10.5-15 Nokian Vativas <img src="/forums/images/graemlins/frown.gif" alt="" />
Re: Pull under braking [Re: Davis5210] #711643 04/01/06 01:17 AM
Nix_Toy Offline
Well, for the braking.. there could be a couple factors. Your caliper can be sticking on the left side. Also, check to make sure your rotor hasn't separated from the hub on the left side... it can happen, 'cause I've done it!
Re: Pull under braking [Re: Nix_Toy] #711644 04/01/06 04:06 AM
TimsToyo Offline
Brake fluid on the pads will make it pull hard to one side also. Check for a leaking wheel cylinder.
Have you pulled the hub and looked at the pads?
'86 Toyo 4wd
'04 600RR
Re: Pull under braking [Re: TimsToyo] #711645 04/01/06 04:45 PM
yodta Offline
yeay, inspect the rotors for contamination first, throw some brake cleaner on them and then...
I 2nd what Nick said...
I had a bad caliper on mine that did the same thing.
this is why it's good to flush your brake fluid periodically -- those parts can get corroded and stop moving freely even though they might still look good.
msg - '87 xtracab
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6018 MB (Peak: 0.6572 MB) Data Comp: Off Server Time: 2026-06-17 06:43:05 UTC
