97 Rodeo suspension #712060 04/02/06 02:01 PM
In the time I have had my Rodeo, I have been through about 4 sets of shocks. I have Monroe Reflex's on currently, about 2 years old. The last change was because the back was bottoming out with even a light load. With the new shocks, I still seemed to have the problem. Honestly this go around, I can't tell whether its the shocks or whether my springs are worn out. How can you isolate which one is worn?? Thanks
Re: 97 Rodeo suspension #712061 04/08/06 03:28 PM
W
wranglert Offline
if the springs are worn you'll get bottoming, shocks only help keep tires from leaving the pavement/unless you're using coil overload shocks. if you dont want to replace your springs(which you will have to do eventually) try the coil overload shocks and throw in a set of helper springs. who knows the back might even come up an inch or 2
90 wrangler 6 cyl. 97 honda passport 84 dodge longbed 4x4
Re: 97 Rodeo suspension #712062 04/09/06 03:53 AM
BobDole Offline
It's definitely the springs. Everyone's leaves seem to get worn and saggy. Install a set of helpers like joe darlingtons. They are listed as 2 inches of lift, so I bet you gain and inch back to stock, and an inch extra. Your ride will improve greatly! If you like, you can crank the front a bit to match. It's easy and improves the ride.
PHP: 7.4.33 Page Time: 0.005s Queries: 14 (0.004s) Memory: 0.5914 MB (Peak: 0.6446 MB) Data Comp: Off Server Time: 2026-06-17 13:25:38 UTC
