best way to adjust rear pinion angle #712166 04/02/06 06:55 PM
akarocket Offline OP
I need to adjust the rear pinion on my truck. I just swapped out a standard u-joint shaft for a CV shaft out of a 2001 4runner. My driveshaft angle right now is sitting at 18 degrees. I measured the pinion and it is pointed up 9 degrees. After the SAS with Marlin springs my truck is still sitting ass low(1.5" lower than front). I would like to use shackles to raise the truck up another inch. My rear shackle right now is 7.5". I need to know how long a shackle I would need to make up the 9 degrees and also lift it up some. I am afraid the shackle would have to be way to long. Might need to use a shim as well. any suggestions?
88 4runner SAS 36 IROKS with some stuff
Re: best way to adjust rear pinion angle [Re: akarocket] #712167 04/02/06 07:01 PM
4Crawler Offline
You'll see about 1 degree of angle change per additional inch of shackle length:
- http://www.4crawler.com/4x4/ForSale/Shackles.shtml#FAQ12
Shims are a more direct option:
- http://www.4crawler.com/4x4/ForSale/Shims.shtml
Or cut off the spring perches and relocate them to the correct angle.
Re: best way to adjust rear pinion angle [Re: 4Crawler] #712168 04/02/06 07:10 PM
would a 9.5" shackle be too long? That would lift the rear 1" and gain me 2 degrees. What size of shim would be needed to make up the rest? I know it does not change directly because you are raising the driveshaft at the same time.
Thanks
Re: best way to adjust rear pinion angle [Re: akarocket] #712169 04/02/06 07:56 PM
4Crawler Offline
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6037 MB (Peak: 0.6601 MB) Data Comp: Off Server Time: 2026-06-13 10:55:44 UTC
