Bearing change on '89 c herokee #712291 04/03/06 04:59 AM
P
papadanny Offline OP
Having trouble getting the wheel hub apart to change out the bearings and seals. The axel came out of the hub now I need the hub out of the bearings. Put alot of pressure from a hydraulic press on it and then got scared of breaking the piece. Am I missing something? All of the bolts are out but still not comming apart. need help. Hub has 197,000 miles on it from the look of the u-joint which is also getting replaced not been well cared for. <img src="/forums/images/graemlins/scared.gif" alt="" /> <img src="/forums/images/graemlins/scared.gif" alt="" /> <img src="/forums/images/graemlins/scared.gif" alt="" />
1988 blue raider weber carb,rancho shocks
Re: Bearing change on '89 c herokee [Re: papadanny] #712292 04/03/06 05:05 AM
JeePete Offline
According to my local parts store, you replace hub and bearing as an assembly on a 4wd 89 cherokee. They sell bearings only, for 2wd only. <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: Bearing change on '89 c herokee [Re: JeePete] #712293 04/03/06 05:12 AM
P
In the Jeep repair manuel that I have it shows it comming apart.
<img src="/forums/images/graemlins/confused.gif" alt="" /> <img src="/forums/images/graemlins/confused.gif" alt="" /> <img src="/forums/images/graemlins/confused.gif" alt="" />
Re: Bearing change on '89 c herokee [Re: papadanny] #712294 04/03/06 05:30 AM
JeePete Offline
I don't know what if any the difference is between the 2wd and the 4wd in the 89. My 93 2wd uses the same hub as a 4wd but the whole hub has to be changed. I just looked it up at partsamerica.com and saw they list bearings for 2wd and hub assemblies for 4wd. ???? press on it some more, if it breaks or bends, a new one can be had for around $68. Maybe it was previously replaced with a unit that isn't supposed to come apart. Good luck! <img src="/forums/images/graemlins/cheers.gif" alt="" />
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6011 MB (Peak: 0.6567 MB) Data Comp: Off Server Time: 2026-06-23 03:12:25 UTC
