Bearing change on '89 c herokee
#712291
04/03/06 04:59 AM
Having trouble getting the wheel hub apart to change out the bearings and seals. The axel came out of the hub now I need the hub out of the bearings. Put alot of pressure from a hydraulic press on it and then got scared of breaking the piece. Am I missing something? All of the bolts are out but still not comming apart. need help. Hub has 197,000 miles on it from the look of the u-joint which is also getting replaced not been well cared for. <img src="/forums/images/graemlins/scared.gif" alt="" /> <img src="/forums/images/graemlins/scared.gif" alt="" /> <img src="/forums/images/graemlins/scared.gif" alt="" />
1988 blue raider weber carb,rancho shocks
Re: Bearing change on '89 c herokee
[Re: papadanny]
#712292
04/03/06 05:05 AM
According to my local parts store, you replace hub and bearing as an assembly on a 4wd 89 cherokee. They sell bearings only, for 2wd only. <img src="/forums/images/graemlins/cheers.gif" alt="" />
[Re: JeePete]
#712293
04/03/06 05:12 AM
In the Jeep repair manuel that I have it shows it comming apart.
<img src="/forums/images/graemlins/confused.gif" alt="" /> <img src="/forums/images/graemlins/confused.gif" alt="" /> <img src="/forums/images/graemlins/confused.gif" alt="" />
[Re: papadanny]
#712294
04/03/06 05:30 AM
I don't know what if any the difference is between the 2wd and the 4wd in the 89. My 93 2wd uses the same hub as a 4wd but the whole hub has to be changed. I just looked it up at partsamerica.com and saw they list bearings for 2wd and hub assemblies for 4wd. ???? press on it some more, if it breaks or bends, a new one can be had for around $68. Maybe it was previously replaced with a unit that isn't supposed to come apart. Good luck! <img src="/forums/images/graemlins/cheers.gif" alt="" />
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6014 MB (Peak: 0.6570 MB) Data Comp: Off Server Time: 2026-06-23 00:47:49 UTCValid HTML 5 and Valid CSS
