90 4runner atuo to 5speed swap #712571 04/04/06 12:13 AM
rodeo157 Offline OP
Hi, ive been tryign to find info on this swap. like a complete parts list. what year cars i can find the parts on. i have the 3.0 auto 4x4. i have that stupid wont shift in the morning problem. and would rather have a 5 speed. any help anyone?
95 rodeo 3.2 liter 5 speed 4 wheel drive. 2" lift. poly bushings. 2 1/4 manderal bent exhaust flow master muff. asin manual hubs, relocated ball joints, custom air intake system
92 rodeo 3.1 2wd auto (wifes)
Re: 90 4runner atuo to 5speed swap [Re: rodeo157] #712572 04/04/06 08:40 AM
rodeo157 Offline OP
can anyone tell me if at least the flywheel will bolt up to the crank or is the auto crank differant. and does the bellhousing fit the block? i need to start finding parts. does anyone know a parts list and what year to find the parts. id really appriciate it
Re: 90 4runner atuo to 5speed swap [Re: rodeo157] #712573 04/05/06 12:03 AM
ToyinAround Offline
The crank is the same, you just need to insert a new pilot bushing and yes bellhousing will mount up as long as you get the parts from a 3.0 truck or 4runner.Your driveshafts should work mine did. You'll need to take very good measurements for the holes to mount the slavecylinder.
You need:
pedal assembly
mastercylinder, slavecylinder, hard line & soft line & mount
Trans & Transfer
shifter boots and suround
I don't know if you'll need the crossmember or not, mine is a 4cyl and i didn't need to change it and i don't think you'll need to change it but can't promise anything.Maybe someone will chime in whos done a 3.0. I have more info but i'm not at home now so i can't send it.
Good luck, Later
1987 4Runner SR5,SAS,6 inches of lift,35in BFG's,Welded Front,Detroit E-Z locker V-6 Rear, 5.29's
Re: 90 4runner atuo to 5speed swap [Re: ToyinAround] #712574 04/06/06 07:30 AM
rodeo157 Offline OP
thanks, anyone know about the ecu. will it effect the computer?
Re: 90 4runner atuo to 5speed swap [Re: rodeo157] #712575 04/06/06 02:13 PM
Kutter Offline
You will need an ECU and engine wiring harness from the 5 speed vehicle. They are different from the auto to 5 speed. You should be able to use parts from 4runners up to year 1995.
If you found a wrecked 5 speed it may be easier to buy it whole and then you would have all the right parts to just swap over.
1995 4Runner Limited V6 3.4 Liter 5 Speed 4x4
1995 4Runner V6 Auto 2WD
Re: 90 4runner atuo to 5speed swap [Re: Kutter] #712576 04/07/06 04:58 AM
rodeo157 Offline OP
i talked to a guy who did the swap and said the auto ecu has better fuel curve and preformance and to leave it, just hot wire the nutral safty switch and reverse lights and leave everything else unplugged. so ima try it that way first. but if i get problems ill swap the harnes and ecu
Re: 90 4runner atuo to 5speed swap [Re: rodeo157] #712577 04/07/06 08:24 AM
rodeo157 Offline OP
ok another problem has come up. can i use the transfer case thats on my AT or do i need a differant t case as well?
Re: 90 4runner atuo to 5speed swap [Re: rodeo157] #712578 04/10/06 04:01 PM
Pedro Offline
you need the 5sp transfer case.
Pedro
95' 4runner 4x4 beige
31" Firestone MT's
ARB winch bumper
custom rear bumper
extended rear breather
Bunch O' Crap in the back seat (highlift axe ect.)
Aluminum safari rack (rip)
PHP: 7.4.33 Page Time: 0.071s Queries: 15 (0.037s) Memory: 0.6193 MB (Peak: 0.6977 MB) Data Comp: Off Server Time: 2026-10-26 07:24:51 UTC
