Page 1 of 3 1 2 3
tick, tick, tick...oh my #712622 04/04/06 02:53 AM
n2dp Offline OP
Today I took my ride in to Midas to have the exhaust pipe connected to the header. Now I can hear the engine instead of the exhaust. My concern is the ôtick, tick, tickö that I hear coming from under the valve cover. I talked to a couple of guys I know and both say to drive it a while and see what happens. I have already spent everything I had on this engine (plus those pretty wheels/tires) and I cannot afford to break this thing right away. What should I be looking for to make me feel more at ease with this thing?
<img src="/forums/images/graemlins/baby.gif" alt="" />
1988 Raider, 2.6L (Weber carb, PaceSetter header, Centerforce D/F clutch, 5-Speed M/T, 33X12.50 Pro Comp M/T, 15X8 US Wheel 97 Series)
3" Body Lift
Re: tick, tick, tick...oh my [Re: n2dp] #712623 04/04/06 03:43 AM
JAVYPRO Offline
Well to give you some comfort that tick tick is kind off natural on these engines. From 1 to 10 how loud is it? mine is about a 4. My wife's GEN III also has that tick tick But if you want to make sure consult with a good mechanic. Good luck <img src="/forums/images/graemlins/kewl.gif" alt="" />
88 red Montero with the Dakar Special Edition decals, 438,000 miles (As of 7/23/2012) some occational blue puffing but still strong and counting!!! I am going ppsshhh (turbo), Stay tuned =) ...
Re: tick, tick, tick...oh my [Re: JAVYPRO] #712624 04/04/06 04:00 AM
stony-man Offline
My '92 3.0 ticks like crazy if I don't change the oil regularly, or if I use a cheapo oil filter. Only does it occaisionally now, and if I rev it slowly to 3500 RPMs, and the let off, it stops. <img src="/forums/images/graemlins/smile.gif" alt="" /> There are a bunch of posts on this topic if you can find them. <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: tick, tick, tick...oh my [Re: n2dp] #712625 04/04/06 04:53 AM
87Montero Offline
My 2.6 with hydrolic lifters never ticked on me.
Do you have mechanical lifters? Either those need adjustment or you just have to do the "slowly revv the engine and back down" for the hydrolic lifters.
Re: tick, tick, tick...oh my [Re: 87Montero] #712626 04/04/06 01:41 PM
n2dp Offline OP
How do I tell the difference?
3" Body Lift
Re: tick, tick, tick...oh my [Re: n2dp] #712627 04/04/06 04:18 PM
don Offline
What oil you using?
I found the top end much quieter with Castrol 20w-50, and better still with Castrol 15W-40 Diesel-rated.
Don `87 Mitsu 2dr, Rubicon survivor, GModified.
Re: tick, tick, tick...oh my [Re: don] #712628 04/04/06 08:04 PM
Worse when cold? Unless you bought a clearwater head with mech lifters (what you usually get when you order a non-jet valve head) or a caravan head from a junk yard, you have hydraulics. Rev to 3500 for 10 seconds, and kill the switch without taking your foot off the gas, OR remove the valve cover and replace the lifters, AND use a stock oil filter and the above suggested oils. Too late to shim the relief valve spring in the oil pump, unless you like major surgery...
Re: tick, tick, tick...oh my [Re: n2dp] #712629 04/04/06 09:02 PM
grass13 Offline
welcome to my world... im still trying to figure out how to defuse the ticking bomb under my hood <img src="/forums/images/graemlins/angry.gif" alt="" />. it all started as soon as i went to "high milage motor oil"... that craps coming out on the next change, and going back to the quakerstate 10/30w.
Re: tick, tick, tick...oh my [Re: grass13] #712630 04/05/06 12:47 AM
n2dp Offline OP
The engine definitely has hydraulic lifters. When I went to work this morning it was fine. Just before lunch I showed a couple of guys and it sounded great. Smooth, no ôtickingöàoooh, I was so proud. <img src="/forums/images/graemlins/notooth.gif" alt="" /> When I got home for lunch, though, it was ticking like crazy.
Pennzoil 10W-40 High Mileage is what I put in. The guys who built the long block recommended 20W-50, but I just thought that was a bit much.
As far as the HM oil, I have been using the 5W-30 since my Æ96 S-10 crossed the 100k mark. I havenÆt noticed any problems, but I am only at 135k now.
3" Body Lift
Re: tick, tick, tick...oh my [Re: n2dp] #712631 04/05/06 01:28 AM
LRJ4x4 Offline
Pennzoil <img src="/forums/images/graemlins/shame.gif" alt="" /> Castrol GTX 15-40 diesel with OEM filter <img src="/forums/images/graemlins/kewl.gif" alt="" />
Page 1 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.009s Queries: 16 (0.005s) Memory: 0.6407 MB (Peak: 0.7651 MB) Data Comp: Off Server Time: 2026-06-17 10:46:52 UTC
