Slip Yoke Orientation? #712835 04/04/06 08:47 PM
rodeo_chris Offline OP
Vehicle: 96 Taco, V6, 4wd, ex-cab, 5spd.
Problem: I took the rear driveshaft apart the other night to replace the universal joint at the rear axle. I unbolted it from the flange on the axle and pulled the slip yoke apart. I didn't think to mark the orientation of the slip yoke before I pulled it apart.
Does anyone know any tricks to getting it lined up again? Or am I just in for a long night of trial and error after work tonight.
Thanks guys.
Chris
94 Rodeo, 35's, 5.38's, locked F&R, Rocker bar on one side, other side in garage
96 Tacoma, DD, pre-dented
Re: Slip Yoke Orientation? [Re: rodeo_chris] #712836 04/04/06 09:32 PM
4WD22R Offline
<img src="/forums/images/graemlins/shame.gif" alt="" /> <img src="/forums/images/graemlins/shame.gif" alt="" />ALWAYS mark drive shafts!!! AFAIK, there is no way to tell, unless you can use something else for orientation, like scratches from brush, etc on the shaft.
BTW, for future reference, it's usually much easier to take the whole drive shaft off at once.....you might not have any problems with it, put her back together and see if you have any vibrations, if not, you're prob good to go.
-1986 TOYOTA
22R
ZUK coil rear
Torqued T-Bars
Marlin HD clutch
AZTTORA #492
TLCA member
"I hear there's rumors on the Internets that we're going to have a draft."
--George W. Bush
Re: Slip Yoke Orientation? [Re: rodeo_chris] #712837 04/05/06 04:43 AM
kewlynx Offline
Line up the 'ears' with the opposite end. I usually prefer to put the trucks on jacks and 'drive' it to make sure I'm in phase, so I don't fubar anything.
**ubi apis- ibi salus**
Re: Slip Yoke Orientation? [Re: kewlynx] #712838 04/05/06 07:30 PM
Thanks guys.
I either got lucky on the first try or it didn't make much difference on my truck.
-chris
Re: Slip Yoke Orientation? [Re: rodeo_chris] #712839 04/06/06 07:59 AM
4WD22R Offline
<img src="/forums/images/graemlins/kewl.gif" alt="" /> <img src="/forums/images/graemlins/kewl.gif" alt="" /> Good to hear! Did you try the "driving" it on jack stands trick? I've done that one a couple times myself <img src="/forums/images/graemlins/smile.gif" alt="" /> <img src="/forums/images/graemlins/smile.gif" alt="" />
-1986 TOYOTA
22R
ZUK coil rear
Torqued T-Bars
Marlin HD clutch
AZTTORA #492
TLCA member
--George W. Bush
PHP: 7.4.33 Page Time: 0.019s Queries: 15 (0.013s) Memory: 0.6069 MB (Peak: 0.6711 MB) Data Comp: Off Server Time: 2026-11-17 11:03:12 UTC
