Engine dies on braking #712946 04/05/06 02:57 AM
mlelah Offline OP
Hi, my '88 2.6L auto runs fine but now the engine dies when I brake as the car is coming to a stop but is still moving. What should I be looking for? I tried searching the forum but couldn't find anything - search words? Thanks.
Michael
Re: Engine dies on braking [Re: mlelah] #712947 04/05/06 05:21 AM
LRJ4x4 Offline
You should be looking for the hood release lever <img src="/forums/images/graemlins/lol.gif" alt="" />
You got to give us more to go on. When did the problem start? Does it just die instantly or does it sputter. Did you recently do anything to the truck? Does it run fine and otherwise have good power? When was the last tune up?
Re: Engine dies on braking [Re: LRJ4x4] #712948 04/05/06 06:42 AM
LandRaider Offline
Put some more gass in it. ? <img src="/forums/images/graemlins/lol.gif" alt="" /> maybe?
Re: Engine dies on braking [Re: LandRaider] #712949 04/05/06 03:17 PM
1. Carb float level
2. large leak in vacuum in brake booster
Re: Engine dies on braking [Re: LRJ4x4] #712950 04/06/06 04:27 AM
mlelah Offline OP
where is the hood release lever? <img src="/forums/images/graemlins/cheers.gif" alt="" />
OK, it kind of just dies as the brake is applied; no sputtering. The engine runs fine and has good power otherwise. All new tune-up parts. I did rebuild the carb during the winter, and I think everything is OK there as I was careful with the float, but I also remember that this started happening before I rebuilt the carb. How can I check if it the float? Thanks.
Re: Engine dies on braking [Re: mlelah] #712951 04/09/06 04:23 AM
Neo Offline
My old CJ7 had the exact same problem and it was a vacuum leak in the brake system = a bugger to figure out since it runs fine in the shop.
1991 JDM SWB Pajero TD - Sold....
1997 Dodge Ram 2500 Cummins 4x4
Re: Engine dies on braking [Re: mlelah] #712952 04/09/06 04:55 AM
LRJ4x4 Offline
Check the vacuum brake booster hose, It's the 1/2 inch one that connects to the manifold between the carb and the firewall. It's OEM only item and likes to crack at the connection point.
Re: Engine dies on braking [Re: mlelah] #712953 04/09/06 03:19 PM
does the motor shut off when you put your clutch in at higher speeds( higher rpm's ), i had this problem and it was fixed when i replaced the emissions control unit and oxygen sensor.
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.6233 MB (Peak: 0.7055 MB) Data Comp: Off Server Time: 2026-06-09 21:28:56 UTC
