Re: CRAZY blow-by... [Re: JeePete] #713035 04/07/06 12:33 AM
DRCYCLOPS Offline
I cant beleive you guys are talking detriot diesel and no one mention runaways that rail is tricky to adjust if one injector is at 3/4 they all are I alway keep a fire extinguiser near by when working on the DD just to snuff out runaways Ive heard storys of those turbo pulling in peices of cardboard and rags
Re: CRAZY blow-by... [Re: JeePete] #713036 04/07/06 04:08 AM
0
05rubi Offline
i take care of lots of genset and firepumps i service a 4-53 that turns 3900 rpm has 2000 hours on it and ive only changed the oil and replaced 1 injector, got a couple of 12v71na with 15,000 hours on them a little dirty but runs great
05 rubicon rustys 3 in susp and ther stuff
Re: CRAZY blow-by... [Re: DRCYCLOPS] #713037 04/07/06 04:15 AM
0
05rubi Offline
ever heard a 16v 149 run back wards <img src="/forums/images/graemlins/scared.gif" alt="" />they fixed the rack later with the soft rack,injector still sticks but the gov can pull the others out of fuel,and the engine will just putt around and fuel knock a little <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: CRAZY blow-by... [Re: 05rubi] #713038 04/07/06 06:08 AM
JeePete Offline
<img src="/forums/images/graemlins/shame.gif" alt="" /> If this wasn't the Jeep tech forum I'd tell some DD & EMD stories, maybe even a few about Cattlepeelers <img src="/forums/images/graemlins/lol.gif" alt="" />. So, My93, did you ever do that oil in the cylinder compression test thing? <img src="/forums/images/graemlins/patriot.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: CRAZY blow-by... #713039 04/08/06 12:48 PM
Tikitgvr Offline
I didnt read all of the posts so if I am repeating anyone I appologize. I had a 98 Dodge that I spoke about in here before with a V8 in (not sure if you have V6) but if you do you described my problem almost identically. On dodges the have a 2 piece intake. The bottom of the intake has a belly pan, which has a gasket, which when blown allows for a tremendous amount of oil to enter your airbox, soaking your filter in oil. This was one of many problems I had.
PHP: 7.4.33 Page Time: 0.015s Queries: 16 (0.012s) Memory: 0.6133 MB (Peak: 0.6949 MB) Data Comp: Off Server Time: 2026-11-17 11:30:43 UTC
