Loud banging from underneath #713095 04/05/06 04:35 PM
n2dp Offline OP
On the way to work this morning mine started making a loud banging moise from underneath. It sounds like somthing loose banging around. I am sure that it is somewhere from the T/C to the rear diff, but not sure what. When it is sitting still there is no noise (except that ticking I was wining about). Any ideas?
1988 Raider, 2.6L (Weber carb, PaceSetter header, Centerforce D/F clutch, 5-Speed M/T, 33X12.50 Pro Comp M/T, 15X8 US Wheel 97 Series)
3" Body Lift
Re: Loud banging from underneath [Re: n2dp] #713096 04/05/06 05:14 PM
don Offline
Crawl under and take a good look. If something's loose, better to find out before you continue driving.
Don `87 Mitsu 2dr, Rubicon survivor, GModified.
Re: Loud banging from underneath [Re: n2dp] #713097 04/05/06 05:19 PM
8
89IsMine Offline
Sound like a tin can full of rocks being dragged under your truck? Take a look where the rear driveshaft enters the transfer case. There's a dust shield there that is friction-fit and may have come loose and is rattling around on the output shaft.
Eric W.
Re: Loud banging from underneath [Re: n2dp] #713098 04/05/06 06:03 PM
grass13 Offline
take a good look at your ujoint at the rear diff, theyll start banging like kids with pots and pans when theyre about to snap.
Re: Loud banging from underneath [Re: grass13] #713099 04/05/06 06:26 PM
n2dp Offline OP
Looks like the wheel was falling off. I tightened them and got it home. I will have to replace all six lugs this weekend.
No one was hurt, so go ahead and laugh. I could have sworn we tightened those. Guess not.
3" Body Lift
Re: Loud banging from underneath [Re: n2dp] #713100 04/06/06 05:39 PM
Have fun. Normal length lugs won't come out without taking stuff way apart....
Re: Loud banging from underneath [Re: n2dp] #713101 04/06/06 06:13 PM
LRJ4x4 Offline
Next time less <img src="/forums/images/graemlins/cheers.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" /> before and more <img src="/forums/images/graemlins/cheers.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" /> after <img src="/forums/images/graemlins/smile.gif" alt="" />
Re: Loud banging from underneath [Re: n2dp] #713102 04/06/06 06:51 PM
DanWheeler Offline
been there - done that. Lucky to be alive. <img src="/forums/images/graemlins/rolleyes.gif" alt="" />
1986 Montero 2.6l
31X10.5 BFG MT - Weber carb with custom intake
Rear LSD - RCI seats - Oil cooler - Manual hubs
Custom bumpers front and rear + rock sliders
Re: Loud banging from underneath [Re: DanWheeler] #713103 04/06/06 06:53 PM
DanWheeler Offline
Gen1 Wheel Stud Replacement HowTo
Replacing Wheel Studs on a Gen1 Mitsubishi Montero
1986 Montero 2.6l
Re: Loud banging from underneath [Re: DanWheeler] #713104 04/07/06 01:37 AM
n2dp Offline OP
Thanks Dan, I can really use those instructions. Of course I laughed when I read 2-3 hours. I set aside Saturday for the one stud on the front passenger side and Sunday for the six on the rear driver side. <img src="/forums/images/graemlins/smile.gif" alt="" />
3" Body Lift
PHP: 7.4.33 Page Time: 0.016s Queries: 15 (0.011s) Memory: 0.6320 MB (Peak: 0.7393 MB) Data Comp: Off Server Time: 2026-11-17 11:22:44 UTC
