Excessive Play on Hub Assembly?? #713200 04/06/06 12:42 AM
barak Offline OP
Ok , I put the front tires on today to see how it sits , looks great , but I noticed a problem right away.When I bounced the front end up and down , the driver side tire was going all over the place.I took the tire off and inspected the hub.I can push and pull on it , and it moves in and out about 1/4" or so , maybe a little more , which when you put a 33" tire on looks pretty bad.Now , I did everything back how it goes , tightened to spec with a torque wrench , and all the ball joints are brand new , so are the tie rods , and pretty much everything else in there.Now , could the tie rods , or lack of pressure in the brake system cause this at all?The other side seems fine , just a hair of play , can hardly notice it.
One other thing that comes to mind , when I put the outer bearing and outer race in , I couldn't remember how it went in.Could it be possible I put it in wrong , or will it only go in one way?I can't even remember if I put it tapered side in or out <img src="/forums/images/graemlins/scared.gif" alt="" /> If no one has any ideas what this could be , I might tearit apart again and try reversing the bearing and race.Anyone with any ideas , no matter what , toss them out there <img src="/forums/images/graemlins/smile.gif" alt="" />
Re: Excessive Play on Hub Assembly?? [Re: barak] #713201 04/06/06 12:58 AM
joe Offline
It sounds like you didn't preload the bearing's. My truck preload was 3.31 lbs. If you don't have a Haynes manual or something like that, I would recommend getting one. It has a lot of useful info like that.
Re: Excessive Play on Hub Assembly?? [Re: barak] #713202 04/06/06 02:11 AM
strawmyers Offline
Isuzu Moderator
Definitely didn't put it in wrong if the rest of it went back together... those things have a rather abrupt taper to them. I'll put in another vote for the preload not being set properly. IIRC, its 2.5-4lbs for an old bearing and new seal; 4.4-5.5 for new bearings and new seal. In case you're not sure how to set the preload:
http://www.planetisuzoo.com/articles.htm/56
HTH and good luck <img src="/forums/images/graemlins/kewl.gif" alt="" />
Sean Strawmyer
Re: Excessive Play on Hub Assembly?? [Re: strawmyers] #713203 04/06/06 05:23 AM
barak Offline OP
Well , never did a bearing preload in my life , so no idea how.I'll read that link you posted and try and learn <img src="/forums/images/graemlins/smile.gif" alt="" />The bearings aren't that old on here , I just re greased them and figured they would go back in how they were.Guess I was wrong <img src="/forums/images/graemlins/notooth.gif" alt="" /> Oh well , hopefully its not too difficult with special tools needed.
Re: Excessive Play on Hub Assembly?? [Re: barak] #713204 04/06/06 07:56 AM
Jim_Paget Offline
The only special tool needed is a fish scale. Shouldn't be too hard to find in Campbell River, just don't use that one you use to support your fishing "tales".
Jim Paget
88 YJ with a few changes
www.rrr4x4.com
Re: Excessive Play on Hub Assembly?? [Re: Jim_Paget] #713205 04/06/06 11:40 AM
barak Offline OP
Surprisingly I have no fishing tales <img src="/forums/images/graemlins/smile.gif" alt="" /> I haven't been out in almost 2 years , and even then it was in the lakes for trout.
I read the article on the bearing repack and preload.I understand the fish scale on the lug nuts to check that.Now , it says to tighten the axle nut as you set the preload.In my case , wouldn't I have tightened it until it was either at preload or past , as I tightened it down.I guess I'll do both sides while I'm at it , get them the same.
PHP: 7.4.33 Page Time: 0.009s Queries: 15 (0.007s) Memory: 0.6108 MB (Peak: 0.6980 MB) Data Comp: Off Server Time: 2026-07-13 16:36:44 UTC
