Steering stabilizer and shock absorber setup #713706 04/06/06 10:41 PM
MarkD Offline OP
My steering stabilizer is in need of replacement (leaking oil) and - based upon the deteriorating condition of the bushings - my shocks are not too far behind. I am thinking about going with a heavy duty stabilizer for smoothness. Can anyone recommend one for a 2WD?
Also, since I use my truck for the daily commute, I was going to get shocks from the dealer (@ $30 per shock). I noticed Pro Comp makes a stabilizer for my 2WD and they also make shocks. Does anyone have any opinions on the ES 1000?
'93 Pickup | 22R-E | 2WD| Yeah...it's my daily ride.
Re: Steering stabilizer and shock absorber setup [Re: MarkD] #713707 04/07/06 04:02 PM
I've used several brands of steering stabilizers on my various trucks and never had a problem with any of them. Rancho, Trailmaster, ProComp all are good. I prefer the direct fit ones that bolt into the stock holes. Good luck getting the old one out, it could turn out to be a really tough job like several of mine have been. You might get lucky and it will pop right out though.
Re: Steering stabilizer and shock absorber setup #713708 04/07/06 04:17 PM
ToyotaT Offline
I'll second the difficult to get out part. Recently replaced mine and it took a 5lb hammer to pop that thing out. Amazingly it didn't start to leak until a couple large pops with that thing.
I went with a Rancho stabilizer. Changed the feel of the steering and helped with bumps. I had to enlarge the hole of the adapter they sent though - that kind of ticked me off. The bolt they sent wouldn't even fit in the hole of the adapter they sent <img src="/forums/images/graemlins/rolleyes.gif" alt="" />
85 Toy Pickup
89 block 30 over and EB RV head/261 cam
Re: Steering stabilizer and shock absorber setup [Re: ToyotaT] #713709 04/08/06 09:33 AM
4WD22R Offline
If you use a tie rod puller or a pickle fork they should come out super easy.......
-1986 TOYOTA
22R
ZUK coil rear
Torqued T-Bars
Marlin HD clutch
AZTTORA #492
TLCA member
"I hear there's rumors on the Internets that we're going to have a draft."
--George W. Bush
Re: Steering stabilizer and shock absorber setup [Re: 4WD22R] #713710 04/08/06 12:36 PM
nuclear3579 Offline
On my '94 pickup, I went with a Pro Comp steering stablizer. The easiest part was putting the new Pro Comp one on.
The hardest part was getting the old one out. Took about an hour...if I ever did it again, I'd let the bolts soak for a week first in PB blast. I too had to resort to pounding the *^(# out of the old stablizer to get it to even budge!
But the Pro Comp was awesome, super easy and no problems. <img src="/forums/images/graemlins/cheers.gif" alt="" />
Too close for missiles, I'm switching to guns...
'97 4Runner...SR5, 4cyl (3RZ), 5spd, 4wd, no rust, excellent shape.
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6060 MB (Peak: 0.6666 MB) Data Comp: Off Server Time: 2026-06-20 18:01:38 UTC
