Water pump for 2.6
#713735
04/07/06 01:14 AM
Is there a high flow water pump available for the 2.6? I've looked and searched without finding anything. what is the best recommended brand water pump that you all are using?
'99 Trooper, 912's '89 Trooper RS, 2.6
Re: Water pump for 2.6
[Re: zKnightWhoSaysNi]
#713736
04/07/06 02:11 AM
IF YOUR RAD IS IN GOOD SHAPE WHY WOULD YOU WANT A HI FLOW WTR PUMP, THE FACTORY PUMP IS PROB ABOUT THE BEST YOU CAN BUY , HOWEVER THEY WILL ONLY RUN AROUND 200.000 MI, JERRY
[Re: JLEMOND]
#713737
04/07/06 06:16 AM
As I get the engine running again, and replace parts related to cooling system that need replacing or are suspect in performance, I want to make upgrades if possible. I want to be as sure as possible of preventing any future overheating problems. Thanks for the input!
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.5912 MB (Peak: 0.6441 MB) Data Comp: Off Server Time: 2026-06-07 11:26:11 UTCValid HTML 5 and Valid CSS
