oil pan help needed! #714130 04/09/06 04:12 AM
RabbitInTheMoon Offline OP
I am tring to replace the oilpan gasket n my 90 model montero (3.0 4x4). I cant seem to get the pan out of the truck even though I have hoisted the motor partaily out. Can any one give me any pointers?
Re: oil pan help needed! [Re: RabbitInTheMoon] #714131 04/09/06 04:40 AM
JAVYPRO Offline
If you removed all the bolts you need then to pry it open but very carefully with a spatula. Good luck <img src="/forums/images/graemlins/kewl.gif" alt="" />
88 red Montero with the Dakar Special Edition decals, 438,000 miles (As of 7/23/2012) some occational blue puffing but still strong and counting!!! I am going ppsshhh (turbo), Stay tuned =) ...
Re: oil pan help needed! [Re: RabbitInTheMoon] #714132 04/09/06 07:03 AM
Kevin C Offline
Assuming its not stuck to the engine and its a clearance problem, you can unbolt the crossmemeber under the engine for more room to work.
Kevin
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.5934 MB (Peak: 0.6464 MB) Data Comp: Off Server Time: 2026-06-07 04:46:12 UTC
