Can you get this certain size tire?
#714211
04/09/06 07:02 PM
Hi, I wanted to ask is a 32x10.5x15" an available tire size you can buy from most popular tire stores? Does BFGoodrich sell this certain size tire in their all terrain model? I know 31x10.5x15" is very popular and almost any tire manufacturer makes this size. If you happen to know please reply back. Thank you.
Salvy
Re: Can you get this certain size tire?
[Re: turboDIESELtrooper]
#714212
04/13/06 05:19 AM
Check the Interco tires website. They make the Swampers and Boggers and always have wierd sizes. BFG does not make that size, though.
[Re: rxinhed]
#714213
04/13/06 09:02 PM
Thanks for your reply. I didn't think BFGoodrich was going to have this particular size tire. I wanna try to go with a 32" tall tire, but at the same time be less wider than 11.5". I'll check Interco out and thanks for the reference.
#714214
04/14/06 01:23 AM
what about going up to a 33x10.5 tire? you have a few more options in that size.
'99 Trooper, 912's '89 Trooper RS, 2.6
[Re: zKnightWhoSaysNi]
#714215
04/14/06 07:26 PM
Speaking of it I was thinking about that size but am not sure if they are too big for the setup I'm going to be running for my 86 Trooper. It's a factory turbo diesel 4 door that I bought with no engine or trans and I plan to drop in the same engine (but non-turbo, the C223). I'll lift it at least 2" and after that I want to get a tire that will make up for the added fender space the 235/75/15" tires leave. I also have to keep in mind that the engine has 58 horsepower and I don't want to run a tire that's too big in the case I can't turn them like the smaller 235/75/15" tires. I was also thinking about 30x9.5x15" for a choice, but the height might not be there. I think I might go with 31x10.5x15" unless a 33x10.5x15" weighs less. It's a decision I'll have to make as I go along with the project and thanks for your reply.
#714216
04/18/06 08:25 AM
tire weights via email from BFG... In regard to weights, we can provide the following information:
All Terrain 31x10.50r15 weighs 41.28 lbs 33x10.50r15 weighs 51.00 lbs
Mud Terrain 31x10.50r15 weighs 44.03 lbs 33x10.50r15 weighs 47.30 lbs
If you have additional questions, please respond to this email or you may call us at 1-877-788-8899 (toll-free) between 8:30AM and 6:00PM Eastern Time Monday through Friday to allow one of our Consumer Relations Representatives to assist you.
BFGoodrich Tires Consumer Relations Department
#714217
04/18/06 08:32 AM
oh and if you didn't already, check out the BFG website. they do have a 33x9.5r15 size in their A/T, but not in the M/T. I didn't get the weight of that one.
#714218
04/20/06 03:19 AM
Wow, zKnight thanks a lot for getting the weight on the BFG tires for me. Really appreciate the info and it's looking like 31x10.5x15" is the route I may go for buying new tires in the future. Thanks again and I'll take a look at the BFG website.
Salvy
#714219
04/20/06 04:34 PM
And...
The weight of the 33x9.50r15 All Terrain is 40.11 lbs
#714220
04/21/06 12:57 PM
Alright, thanks again for the info and help. I appreciate it. The 33x9.5x15" tire is what I wanted to go with originally, but after a 2-2.5" suspension lift some people were saying it may be somewhat unstable and have the possibility of rolling given the tire is tall and narrow. I don't think it's that big of an issue, do you? I wanna try to keep running the original 15x6" rims that came factory on the 86, so in turn that will be a wide enough rim for the 33x9.5x15" tire I think.
