Need some help trying to diagnose why my right front rotor is rubbing on the caliper. There were no issues before going to URE, but after a couple of trails I had a squeeking from the front end. Not real bad, just a faint noise. I thought I just had dirt in the pads or something.
It got worse on the ride home, so I took the tire off and had a look. The caliper was firmly bolted in place, but the rotor had some play in it. The bolts that hold it to the hub? (don't know the name of the part) where the wheel stud's are had backed out a couple of threads and the rotor was loose.
I tightened all of them down but after driving back to school, I'm having similar grinding/squeeking noise from the same brake. Any ideas/suggestions? All help appreciated.
Brad
95 Trooper,3in Lift,15x10 AR-23 Wheels, 33x12.50 BFG AT's, SuperWinch Hubs,Rock Sliders,Tie-Rod Shields,Cross-Drilled Brake Rotors,ARB Bull Bar...,looking for cheap winch.
