rims for 85 4 runner #714700 04/11/06 01:16 AM
Roland2655 Offline OP
Hope this is an easy one. Can you put tacoma rims on an older 4 runner. Big question is clearance for the hubs in the front.
thanks
ridge runner
Re: rims for 85 4 runner [Re: Roland2655] #714701 04/11/06 01:23 AM
zman2day Offline
15's for sure won't fit...tried won't clear the calipers. Not sure about 16's though?
Zman2day
Trail rig*exo'd '85 4Runner - 5"Allpro Extreme, 5.29's, Detroits F&R, FJ80 HP, 30spl cromo Longs, Marlin 23spl dual ultimate crawler, linelocked, hydro-assisted on 37" Krawlers
-Tow Rig - '02 Excursion 7.3 PDS
Re: rims for 85 4 runner [Re: zman2day] #714702 04/11/06 01:39 AM
4WD22R Offline
I run 15's on my '86 and the '85 I'm getting has 15's as well, AFAIK, 15's were stock <img src="/forums/images/graemlins/confused.gif" alt="" />
I don't think that the hub will fit through the rim. Where are you getting them from? see if you can do a test fit.
-1986 TOYOTA
22R
ZUK coil rear
Torqued T-Bars
Marlin HD clutch
AZTTORA #492
TLCA member
"I hear there's rumors on the Internets that we're going to have a draft."
--George W. Bush
Re: rims for 85 4 runner [Re: Roland2655] #714703 04/11/06 02:18 AM
Mojavewanderer Offline
They should fit over the hubs, but you may run into a backspacing problem. I have a set of Sequoia rims, and they fit over the hubs on my 80 without any problem, but they don't clear the tie rods. Do a test fitting if you can.
1980 Hilux 4x4 stock for now...
2003 Tacoma Doublecab 4x4 2 inch lift, 32" BFG All Terrains, NO CHROME!
Re: rims for 85 4 runner [Re: 4WD22R] #714704 04/11/06 10:23 AM
zman2day Offline
Just to clarify,
I could not fit 15 inch 95.5+ Tacoma wheels on my 85. They fit on the back but NOT on the front. They actually hit the stock steering arms and tie rods first.
Of course they came stock with 15's <img src="/forums/images/graemlins/drunk.gif" alt="" /> but believe the question is about Tacoma wheels NOT stock. <img src="/forums/images/graemlins/confused.gif" alt="" />
Zman2day
Re: rims for 85 4 runner [Re: Roland2655] #714705 04/11/06 01:59 PM
superv43 Offline
The 16" steel Tacoma wheels just barely clear the tie rod end on my 85 pickup. You may get some contact with any large balance weights on the inner rim. A 1/4" spacer will take care of these issues. No issues with the center hole at all. I really like these wheels as they are all Toyota quality, much thicker steel than most of the black wagon wheel replacements out there. I had them stripped and powdercoated black and they are holding up very well.
Re: rims for 85 4 runner [Re: superv43] #714706 04/11/06 02:30 PM
Well since I also own a tacoma with the TRD rims. I guess its on me to find out if they will work or not. My guess is there might be clearance problem in the front with the rotors if anything, or the hole won't be big enough for the manual hubs to fit.
ridge runner
Re: rims for 85 4 runner [Re: Roland2655] #714707 04/11/06 04:29 PM
Nix_Toy Offline
I dont' see why there would be a problem with the hub cut-out hole.. some Tacoma's came with manual hubs too
Re: rims for 85 4 runner [Re: Nix_Toy] #714708 04/11/06 05:25 PM
kyle-22r Offline
because the backspacing is wrong! the most you want to have on a straight axle truck is 3.75". IFS trucks and tacomas IIRC had 4.5" backspacing.
'91 4x4 shortbed
22R-E, W56, the dd!
Re: rims for 85 4 runner [Re: Roland2655] #714709 04/11/06 06:53 PM
hupptoy Offline
My 99 4Runner stock Aluminum 16" wheels would not fit on the front of my 80 Pickup.
Also, the stock 83 steel wheels would not fit on the front of my 99 4Runner, but does on the 93 Pickup.
I was playing around last year while I was rotating tires and wanted to see how bad the interference actually is.
hupptoy
99 4Runner SR5 3.4 Auto 4x4, 32" LTX A/T, 154K
93 Toy x-cab 22RE 5-spd 4x4, 31" LTX A/T, 150K
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6314 MB (Peak: 0.7386 MB) Data Comp: Off Server Time: 2026-06-20 19:06:06 UTC
