Frame Rot To Avoid! #715272 04/13/06 12:04 AM
barak Offline OP
Ok guys , as promised here a re a few pic of the frame now that the body is off so you can get a better look at the damage.If you don't flush the crud out of the frame every once ina while , this could happen to you too.The thing with this rot is it starts from the inside , so you don't notice it , and once you do , its too late , the frame is not fixable , no matter how good you are at welding <img src="/forums/images/graemlins/nana.gif" alt="" /> My advice to anyone , is if your in doubt about your frames condition , check it with a hammer or a screwdriver , make sure you can't poke a hole in it , if you can , get it checked to see if its fixable still , if its not , look for a good frame and do a complete swap like I am doing.
As you look at the pics , you will see a few spots where the frame is broken , missing parts of it , or has big holes in it.You'll see what I mean right away as you look closely.
So , after reading this post , I hope I inspire at least a few of you to check your frames.Don't get to the point where you have to do a big project like me , although I did make it bigger while doing lots of other stuff at the same time.Its a lot easier to do everything as you go and have it all done at once. <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: Frame Rot To Avoid! [Re: barak] #715273 04/13/06 01:45 AM
lttlbddy Offline
Amazing! Usually when I have seen frames like that, everything else is rusted also. You body doesn't look to bad, the axle looks to be in good shape . . . amazing.
Re: Frame Rot To Avoid! [Re: lttlbddy] #715274 04/13/06 01:51 AM
ISueYou Offline
ahhhh.....that sweet salty air!
1989 Trooper 2.8 V6 5-Speed(the daily driver)- Superwinch Hubs, otherwise Stock - $350
1990 Trooper LS 2.8 V6 Auto - Superwinch Hubs, otherwise stock....for now - $182.50
1983 Chevy Blazer - Stock - $150
No Car Payments - PRICELESS
Re: Frame Rot To Avoid! [Re: ISueYou] #715275 04/13/06 03:49 AM
Iluvmud Offline
Damn!!! Looks like it is time for a tube frame truggy lay out huh? <img src="/forums/images/graemlins/wink.gif" alt="" />
8 inches of lift, 33s, custom bumpers and rockbars, powertrax, T-maxx 9000, lots o lights, and some bass in the trunk
Lifted, locked, and ready to rock!!! <img src="/forums/images/graemlins/evil.gif" alt="" />
[url=http://www.cardomain.com/memberpage/743285][/url]
Re: Frame Rot To Avoid! [Re: Iluvmud] #715276 04/13/06 06:46 PM
Moondawg Offline
Hey Barak,
I am in Victoria, BC on the Island too. My 88 Troop has a bit of lower body rust, but the frame is in good shape. I can't believe how nasty yours is. It must have spent some time somewhere close to the ocean (Tofino) or where there is lots of road salt used. I will definitely check my frame over again.
Where are you on the island?
My 88 has been reserected lately. Rebuilt motor as the head needed to be done; Did bottom end too. AMC head installed. New heater core, still an IFS but new seals, bushings, ball joints, tie rods all around.
Cya, Grant.
88 TrooperII
Re: Frame Rot To Avoid! [Re: barak] #715277 04/13/06 08:03 PM
strawmyers Offline
Isuzu Moderator
look closely.
That won't be necessary... I could take my contacts out and stand 30' away from my computer screen and still tell that your frame is FUBAR'd <img src="/forums/images/graemlins/scared.gif" alt="" /> My frame is pretty rusty from all of the road salt they dump during the winter. This post is good inspiration to give it a quality once-over. Kinda scared what I might find, now <img src="/forums/images/graemlins/lol.gif" alt="" />
Sean Strawmyer
Re: Frame Rot To Avoid! [Re: barak] #715278 04/13/06 08:09 PM
W
Wayne Offline
Holy Cow, I am surprised the whole thing didn't collapse on you with a good bump!
You're very lucky to have avoided a serious accident.
It looks like you rinsed off the road salt every couple of days by driving it in the ocean.
[color:"white"]? 04 Rodeo DI ?[/color] 75k mi, body damage on the 1st weekend I got it.
Re: Frame Rot To Avoid! [Re: Wayne] #715279 04/13/06 08:42 PM
BigSwede Offline
As I have been laying under the Trooper installing the Teralows, I have been looking at all the rust. Bad as it looks, it is nothing like that!
There are definitely some areas that look ready to fold up on you...
Serenity now!
Re: Frame Rot To Avoid! [Re: BigSwede] #715280 04/13/06 09:30 PM
barak Offline OP
Well , I can honestly say this frame wasn't ruined by road salt , as I have had many vehicles and never anything this bad <img src="/forums/images/graemlins/smile.gif" alt="" /> The problem was the guy that had it before used it almost every day to drive about 30 miles on a muddy road , and never flushed the frame.The inside of the frame had about a hundred pounds of mud , caked in there so hard it was like rock.And with that mud just sitting in there , it rotted the frame from the inside out , so you would never know untill it started to show.
Yes , the frame did snap on a bump , both sides of the driver side leaf spring , there was nothing left to hold it on <img src="/forums/images/graemlins/lol.gif" alt="" /> It was basicaly being held there by the body , and before I took the body off , the driver side sat about 3-4 inches lower than the passenger side.
Hey moondawg , if your ever down this way let me know.I am hoping to have my truck all done in the near future so I can go out and play.
PHP: 7.4.33 Page Time: 0.009s Queries: 15 (0.005s) Memory: 0.6302 MB (Peak: 0.7364 MB) Data Comp: Off Server Time: 2026-06-07 06:10:44 UTC
