2000 Passport Automatic - Slipping 1st gear?! #715341 04/13/06 06:14 AM
TeamPSI Offline OP
My dad has a 2000 Passport with an auto. He said that it seems to be slipping in 1st gear. It was an instant problem. IT never slipped until one morning when he drove it to work.
He said thatslowly gassing it makes it seem better. He said it feels like the slippage you would encounter with a low fluid level...Yes the trans is full of fluid.
Anyone have this problem? Im hoping that it could be something other than "rebuild time".
1996 Rodeo 3.2l 4wd
3" Indy4x lift - 3" Body Lift - Calmini torsion bars - Superwinch hubs - Independent4x brake lines - 32x10.5x15 Pro Comp MT's - Flowmaster 2.5" cat-back - Indy4x Tie Rods - Rear Lockright
Re: 2000 Passport Automatic - Slipping 1st gear?! [Re: TeamPSI] #715342 04/13/06 11:27 AM
rodeoredd Offline
from what you describe it sounds like an issue i had a few years ago. turned out to be the TPS (throttle position sensor) put a new one in and all was wonderful in shifting land.
but, that should throw a code. if the passport has no codes - probably isn't that
'99 Rodeo V6 4x4 w/ 8" lift, 33" TrXus MT
4.77, Aussie Locked rear, 8500lb winch, custom rack, custom winch bumper, ProComp lights, 230,000km
http://www.cardomain.com/ride/2231794
Re: 2000 Passport Automatic - Slipping 1st gear?! [Re: TeamPSI] #715343 04/13/06 04:14 PM
SteveV Offline
If you have a limited slip rear differential and you changed the gear oil but didn't add limited slip additive to the new gear oil, that will cause the clutch plates in the differential to chatter. It feels almost like a slipping transmission as you take off from a stop.
1997 Trooper
2002 Rodeo
Re: 2000 Passport Automatic - Slipping 1st gear?! [Re: SteveV] #715344 04/14/06 07:29 PM
TeamPSI Offline OP
Ill get him to stop by Autozone for a scan.
Im pretty sure the rear diff fluid hasnt been changed.
Thanks!
1996 Rodeo 3.2l 4wd
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6033 MB (Peak: 0.6586 MB) Data Comp: Off Server Time: 2026-06-07 04:26:18 UTC
