front end vibration during take off #715531 04/14/06 01:10 AM
Roland2655 Offline OP
I have an 85 pick up with a solid axle and when I take off from a stop I get wheel hop in the front tires. I had 31's on it was pretty noticable. Went back to factory recommended tires and it isn't quite as bad. Any ideas where i should start looking for the problem?
ridge runner
Re: front end vibration during take off [Re: Roland2655] #715532 04/14/06 01:25 AM
OOP'S Offline
When do you get this wheel hop, on the street or in the dirt?
David Fritzsche
Roseville, CA
"Serenity through Sobriety"
Re: front end vibration during take off [Re: OOP'S] #715533 04/14/06 01:33 AM
Sorry on the street. No problem when it is in 4x4.
ridge runner
Re: front end vibration during take off [Re: Roland2655] #715534 04/14/06 02:26 AM
OOP'S Offline
Are you sure it is the front end chattering? I am wondering if it is clutch chatter that is causing the whole truck to shake. How is the clutch? Do you have any oil leaking out of the bellhousing? You (I hope) are not driving with it in four wheel drive on the street are you? Running the larger tires and stock gears can FUBAR a clutch.
David Fritzsche
Roseville, CA
Re: front end vibration during take off [Re: OOP'S] #715535 04/14/06 02:48 AM
a freind of mine has a 92 toyota truck and was haveing the same problem with his truck wheel hopping when taking off from a start, he put a new stock clucth,pressure plate and new t.o. bearing and the whole shimmy shake and hopping went away.
good luck with it. <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: front end vibration during take off #715536 04/14/06 05:32 AM
Toy Story Offline
Front wheel hop on the street when it's not in 4 wheel drive? <img src="/forums/images/graemlins/confused.gif" alt="" />
Are you sure it's wheel hop?
85 Toyota SR5 Xtra Cab P/U
Re: front end vibration during take off [Re: OOP'S] #715537 04/14/06 03:18 PM
I guess it could be the clutch? However there isn't any slipping that I can tell. The vibration is coming through the steering wheel from the front end not the rear. It feels more like worn out bushings (there pretty shot from age)
FWIW, you drive a solid axle around the first turn in 4x4 on black top and that'll wake you up in hurry.
Guess I'll put ole' Rosco in the shop and have them check him out.
ridge runner
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.6115 MB (Peak: 0.6888 MB) Data Comp: Off Server Time: 2026-06-20 20:14:39 UTC
